When trying to scan, I encounter an error code: 2,178,0 and message "Scanner driver will be closed". The lamp is lit but scanning cycle aborts before light can move thru it's scan cycle. I don't know if the lamp is somehow an issue. I have reinstalled the scanner with a recently downloaded driver; Windows shows "device working properly". Scanner worked fine for over 2 years before this started.
I need a hendheld pen scan
suitable for XP and editable on word,
to save especially half of the...
(More)
to save especially half of the lines not the all page,also it should write-
I need wireless one,with large memory,which can run on batteries I can recharge on the USB port.
do ou reccommend anything please?
I m going to use it in Europe
on Bugarian and Turkish
thanks a lot
I have a umax powerlook 1100 scanner and it was not a cheap scanner but since I have bought my new...
(More)
I have a umax powerlook 1100 scanner and it was not a cheap scanner but since I have bought my new Mac Pro, Quad-Core Intel Xeon, 2.93 GHz Its not seen the scanner, I know that UMAX stopped doing there scanner software so what can I do to be able to scan again.
I have a Visioneer one touch 9120USB scanner and I use windows xp. I have uninstalled and...
(More)
I have a Visioneer one touch 9120USB scanner and I use windows xp. I have uninstalled and reinstalled the software. I get the message after the computer tries to load the scanner of "unable to connect with scanner". The scanner is connected to the computer and connected to power.
message received Release the lock switch,detach the usb cable and reconnect. Tried this but it...
(More)
message received Release the lock switch,detach the usb cable and reconnect. Tried this but it doesn't work. The scanner is not locked!
