Question about Rinnai Vent Free Gas Heater/: 6,000 BTU RCE-229A
Error code 12
Unit is 2 years old been working fine.works for 2 hours and error code 12.now unit doesn't last 1 minute before failure
rinnai rce-606tra 2
  • dieseldon Mar 28, 2008
    I get the same problem. I have 2 units - one does not exhibit this problem. Any idea what error code 12 is?
  • 1,420 Answers
Error code 12 is a genaric "Flame Failure" code. I suspect that the flame is not hitting the flame sensor or that the sensor is bad. You will need to get to the sensor located on the far left hand side of the unit. If you have the owners manual, it's part #123. Remove it and clean it off. Make sure it is placed back in the heater properly aligned and all the way in. Then try and light it. If it does not stay lit, it may need to be replaced but check out the burner tray for debris not allowing the flame to travel all the way to the sensor. You will have to remove many parts to get to the burner assembly.
Posted on Jun 03, 2008
How to fix gas heater Rinnai RCE-229H?
get a gas fitter in to fix the problem as gas is less forgiving than electricity
Jul 19, 2015 | Rinnai Heating & Cooling
Rinnai IB35ETR shows error 12 after room temperature reaches the set value, restarting it will show error code 11
Hi there, i have same unit and its got error 70 coming up. Which is faulty on off switch as per manual. I can confirm on off button on control panel, up on top is not working however remote is working. When i try to start it with remote it comes up but turns itself off with error 70 again. I tried to remove this control panel (pcb) from unit however it is still doing same. Now i am not sure if it is actually pcb panel which is faulty ? Please help ;)
Jul 15, 2014 | Rinnai Heating & Cooling
Rinnai RC98i Error 12 - Flame Failure
IF THIS UNIT HAS SPARK IGNITION THE IGNITORS ARE PROBABLY OUT OF ADJUSTMENT WHICH IS LIKE HAVING TO WIDE OF A GAP ON A SPARK PLUG . IF YOU MAKE GAP OF IGNITOR ELECTRODES APPROXIMATELY 1/8TH OF AN INCH APART IT SHOULD LIGHT AS LONG AS YOU ARE GETTING VOLTAGE FROM IGNITION COIL. CALL A SERVICE TECH
Dec 22, 2013 | Rinnai RC98i Tankless Water Heater 9.8 GPM...
Hi I have an old Rinnai RCE 417H natual gas unit
needs a service a clean and check of the ignition secquence. should only have green light for power and red light for Lighting. large screen can be bought from Rinnai part supplies
Jun 14, 2011 | Heating & Cooling
WONT START AND LIGHTS FLASH
try interrupting power to reset.if it still doesnt work consult manual for code to flashing light sequence.also make gas supply is on
Jun 23, 2009 | Rinnai Vent Free Gas Heater/: 6,000 BTU...
Rheem RTG 53 PVN with fault codes C4 or C7
I had the same problem with my tankless waterheater (flashing c4 76 alternately). I called Rheem
tech support and they had me 1 power down the remotepanel 2 unplug the unit from the wall 3 remove the cover 4 remove the wires for the remote panel from the circuit board and pull the twisted pair that goes to the remote out from the bottom of the unit. 5 reinstall the cover 6 plug the unit back
into the wall and turn on the hot water see if it works. It did in my case and they are sending me a new remote panel. I hope it helps.........
Nov 21, 2008 | Rheem RTG-53PVN Indoor Natural Gas...
Rinnai 606tra error code 31
since the e mail you sent to me was do noy reply i will try to get my point across here.
i posted my question on your 10 buck forum the answer i got was read the manual and now after posting on your free forum the reply i get is to try posting in the 10 buck forum. sound like a run around to me
Oct 04, 2008 | Rinnai Unvented Gas Zone Heater. 99% fuel...
Hi - I have a Rinnai Convector 406 gas heater which is 2 years old. Yesterday, it started cutting out with an error code of "12" showing in the display. It can be re-started but only stays on for a few...
I believe the 12 is the error code for "incomplete combustion". In this case you will want to start with the thermocouple. If you are not handy at these things I would call a service tech. You can find a service person on their website.
http://www.rinnai.us/
Jun 15, 2008 | Rinnai Heating & Cooling
Open Questions:
See all Rinnai Vent Free Gas Heater/: 6,000 BTU RCE-229A Questions
Heating & Cooling Logo
891 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
