2003 Ford Mustang Logo
Posted on Nov 07, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Electronic flasher location on 2003 mustang gt
Anonymous
Level 3:
Brigadier General:
  • Master 3,533 Answers
  • Posted on Nov 07, 2009
Anonymous
Master
Level 3:
Brigadier General:
Answers
3533
Questions
Helped
1421184
Points
10516
For the most part its under the dash on the driver side give these websites a try www.autozone.co and www.alldatadiy.com if all fails stop by your local Ford dealership in the parts department and they will print you out pictures and diagram showing you where its located wish you the best Michiagn Man.
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Nov 18, 2009
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
1209
Points
Wher is the fuel reset on 2003 ford mustang
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 5 Answers
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
5
Questions
0
Helped
1837
Points
15
Do You Mean that or what?
Electronic Turn flasher Any one know the best way to connect a three prong elecronic turn signal flasher into the two prong 68 wireing connectors?
I have just changed the three bulb sequential tail/ turn signal set up to an LED system. Besides the cool factor, the increased brightness of the LED's over the 1157 bulbs is a great safety bonus and the lower current draw puts less of a load on the 37 year old wireing.
I want to go to an electronic flasher to fine tune the flash rate and the only ones I could source are three pronged.
http://img.photobucket.com/albums/v2...llights011.jpg
http://img.photobucket.com/albums/v2...llights026.jpg
http://img.photobucket.com/albums/v2...llights025.jpg
http://img.photobucket.com/albums/v2...llights007.jpg
send me a message [email protected]
1 Related Answer
Steeler Ed
  • 130 Answers
  • Posted on May 02, 2009
SOURCE: electronc flasher
The electronic flasher fuse is at location 13 in the fuse box. The fuse panel is located below and to the left of the steering wheel by the brake pedal. Remove the panel cover to access the fuses
The Flasher Relay is located on the passanger side behind the center console(radio and climate control stuff)....it is a 2 prong, pale green cylinder relay with a square nipple attaching it to a piece of metal to keep it in place. If you open the passanger side and lean into the floor board and look up over the main support brackets for the radio it should be right there. It has a wire attached to it. It may even have "FLASHER" printed on it. If anyone made changes to the radio or other electronics, it may be moved.
My 2003 mustang gt misses a little when I give it gas to pass someone. Is it electronical?
does it have a coolant leak or have you washed the engine? Mine will miss under load if i get water under the coils...
I want to know where the electronic flasher is located in my 1994 Ford Mustang. I need to replace it.
inside car on fuse box. under drivers side. LID will have a diagram showing location
I have a 1995 mustang gt the flashers & turn signals stopped working i replaced 1 an number 5 fuse still not working
Replace the flasher which is on the passenger compartment fuse block. It isn't like the old round ones. It is at the bottom.
2helpful
Electronc flasher
14helpful
5answers
Turn Signal Flasher location in 93 Mustang GT
The flasher is a small round plastic cylinder (unless replaced with a metal one) behind the left edge of the glove box that will look similar to the one in the fuse panel. The first step is to squeeze gently both sides of the open glove box and let it swing downward. It will be snapped into a metal horizontal brace just to the left of the glovebox opening by a small tab and have two wires attached. The number more than likely will be a #552 although I have seen a factory one with a Warner #224
Top Ford Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
xxxxxx xxx
Are you a Ford Expert? Answer questions, earn points and help others
