Question about NetGear WGR614 Wireless Router
Connecting to Internet
My wireless network connection is fine, but I can't get to my internet provider. the ISP, of course, says that it is the router's fault, but provides no help to fix the problem
  • 2 more comments
  • smedleyj Jan 11, 2008
    Apologize for not telling you sooner, but I restored the internet connection. You, and our ISP, were correct in that the issue was with the router. I had to figure out that I just needed the router's IP address. Why the ISP could not tell me that is beyond me.
    Thank you for following up.
    smedleyj
  • Gamyd Feb 18, 2008
    I cannot access the internet when I use my WGR614v4
  • shawnmalki Jan 07, 2009
    icant gottointernenet
  • xenocide May 11, 2010
    1. Is your modem plugged into the correct port on your router?(simple, but something to check)
    2. What do you mean by you cant get to your internet provider? I'm used to cable, but most of the settings that dsl requires are set in your router as far as I'm concerned
Wath the pin number
Posted on Feb 02, 2012
How can i find out what the password or pin # is for the router
Posted on Jan 25, 2008
I have just bought an acer iconia w3-810. When starting the set up process I can't connect to the Internet. It says I have no connection to internet. Tried setting up a network and it can't find my...
try connecting to another location like the public library. it could be that your router security setting may be set too high.
http://brandzone.bz/files/catalog/upload/5/8/planshet-acer-iconia-w3-en.pdf
Wireless networks - 29
Installation speed and simplicity Installing a wireless LAN system can be fast and easy and eliminates the need to pull cables through walls and ceilings. Components of a wireless LAN To set up your Wireless network at home you need to have the following:
Access point (router)
Access points (routers) are two-way transceivers that broadcast data into the surrounding environment. Access points act as a mediator between wired and wireless network. Most routers have a built-in DSL modem that will allow you access to a high speed DSL internet connection. The ISP (Internet Service Provider) you have chosen normally supplies a modem/router with the subscription to their services. Read carefully the documentation supplied
with your Access point/router for detailed setup instructions
Feb 03, 2015 | Tablets & eReaders
Direct access through LAN cable internet was working fine. whereas while connecting through DLink(Dir 600) pages were not loading correcly. I tried Netgear modem it was working fine. What is the probl
I would contact your ISP for help with this one. It should work but you would want to check the LAN and WAN settings to make sure they work on the network since there have been changes.
Aug 31, 2014 | D-Link Dlink Dir-600 Wireless Router...
How Do I connect to internet with my desktop without Ethernet cable
To connect wireless to a network ..you need a wireless router or access to a near by one ..and you need to install a wireless card on computer if it has non ..This can be a pci card and you will install it on a pci slot inside and install its driver and after that connect to the network available ..or use a wireless card on usb ..
If you do not have a network free near by ..you can connect using the wireless card to another computer connected to the internet ..or install a wireless router on your Ethernet cable ..and a card in computer or a usb one ..
In my opinion the wireless card and router is the best way cause connecting trough another computer can be tricky and slow..
another way ..if you do not have any other means is to use a wireless modem on usb from a mobile network ISP (internet service provider )
This can be the same provider as your mobile phone one ..
Dec 18, 2011 | Dell Dimension 4500 PC Desktop
What do I do to have my wireless working away from my Internet connection and wireless Router. I have 2 Ethernet cables one going from my router to my Laptop and one going from my Router to my Internet...
Ok. As per your statement your laptop is working perfectly , when you are connected your laptop with with the cable wire.So the network cable is OK. So you have to configured the wireless cable in your laptop when it is connected to your laptop. After connecting the cable wire to your laptop you have to findout the gate way of your ISP ( Internet Service Provider). To find out the gate way , kindly follow the following instructions.
First findout the IP address , subnet mask,and Gateway addresses of your ISP ( InternetService Provider ).To find out the above mentionedaddresses first open the control panel -> network connections -> local area connction -> properties -> Internet Protocol Version 4(TCP/IPV4) OR Internet Protocol Version 6 (TCP/IPV6)according to your ISP -> Properties
By the systematic selection as mentioned above you will get the IP address, subnet mask and Gateway addresses. Kindly note the Gate way address of your ISP. Then enter the gateway address in the browser and open the window. Then a control panel / a window will appear. It will prompt you to enter 1). user name, and 2) password. If you are having the user name and passwords provided by your ISP , kindly enter them in the window and click to open. Then the particulars of your ISP will be displayed in the window. Then click the wireless icon and click to enable. Hurray ! your laptop will work perfectly through wireless. If you are not aware of about the 1). User name and 2). password , you must approached to your ISP and try obtain the same for working of your laptop wirelessly. Provided , that you have to configure the wireless enabling for both the ethernet cables and there after save the changes , after finding the 'GATEWAYS' if both the the ISP's seperately.
Oct 03, 2010 | D-Link DI 514 Wireless Router (DI-514)
Having problems connecting my lap top to my wireless cable modem. Its a motorola SBG900 gateway. everything seems to be connected. Im able to use it with a ethernet cable just need help geting it to be...
By the systematic selection as mentioned above you will get the IP address, subnet mask and Gateway addresses. Kindly note the Gate way address of your ISP. Then enter the gateway address in the browser and open the window. Then a control panel / a window will appear. It will prompt you to enter 1). user name, and 2) password. If you are having the user name and passwords provided by your ISP , kindly enter them in the window and click to open. Then the particulars of Motorola SURFboard SBG900 Wireless Router will be displayed in the window. Then click the wireless icon and click to enable. Hurray ! your laptop will work perfectly through wireless. If you are not aware of about the 1). User name and 2). password , you must approached to your ISP and try obtain the same for working of your laptop wirelessly.
Oct 03, 2010 | Arris SURFboard SBG900 Wireless Router...
Lap top not connecting to internet
GO TO CONTROL PANEL,
CLICK ON NETWORK SHARING CENTRE(WIN 7)
click on,Connect to a Network.If this doesn't lead to an internet connection you may have cable faults or port configuration not set up correctly.You must have an internet service provider(ISP).
Aug 07, 2010 | D-Link DIR-615 Wireless Router
I just brought a dell 10' netbook and i have dial up phone service so how can i get the internet on my netbook with dial up service?
Here is the internet setup info for that netbook from Dell's website ...
Setting up Your Internet Connection To connect to the Internet, you need a modem or network connection and an Internet Service provider (ISP).
To set up an Internet connection with a provided ISP desktop shortcut:
  1. Save and close any open files, and exit any open programs.
  2. Double-click the ISP icon on the Microsoft® Windows® desktop.
  3. Follow the instructions on the screen to complete the setup.
note.gif NOTE: Have your ISP information ready. If you do not have an ISP, the Connect to the Internet wizard can help you obtain one.
If you do not have an ISP icon on your desktop or if you want to set up an Internet connection with a different ISP:
Windows Vista®
  2. Click Start interne3.jpg ® Control Panel® Network and Internet.
  3. Under Network and Sharing Center, click Connect to the Internet.
The Connect to the Internet window appears.
  1. Click either Broadband (PPPoE), Wireless, or Dial-up, depending on how you want to connect:
    • Choose Broadband if you will use a DSL modem, cable TV modem, or satellite modem.
    • Choose Wireless if you will use a wireless connection through a WLAN card.
    • Choose Dial-up if you will use a dial-up modem or ISDN (Integrated Services Digital Network).
note.gif NOTE: If you do not know which type of connection to select, click Help me choose or contact your ISP.
  1. Follow the instructions on the screen and use the setup information provided by your ISP to complete the setup.
Windows® XP
  2. Click Start interne6.jpg ® Control Panel® Network and Internet Connections.
  3. Click Set up or change your Internet connection.
  4. Click Setup. New Connection Wizard window appears.
  5. Click Next. Choose Connect to the Internet and click Next.
  6. Click Set up my connection manually and click Next.
  7. Click either Broadband (PPPoE), Wireless, or Dial-up, depending on how you want to connect.
And here is the link to where the info was found...
http://support.dell.com/support/edocs/systems/xlob/dtg/en/internea.htm#wp1012333
and another with more info on that netbook ..
http://support.dell.com/support/edocs/systems/xlob/dtg/en/index.htm
Apr 06, 2010 | Dell Inspiron Mini 10v Netbook Computer
Canot connect wireless
Make sure that your wireless is set to access point only and not firewall mode.
Feb 03, 2008 | Buffalo Technology WHR-G54S Wireless...
NetGear WGR614 Wireless Router Logo
296 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
