Mitsubishi WS-55513 55 in. Rear Projection HDTV Television
Problem for Mitsubishi WS-55513 55 in. Rear Projection HDTV Television
Have wavy lines in picture sometimes-could this be
By dolliegrenie on Nov 07, 2009
have wavy lines in picture sometimes-could this be a faulty wire?
Best Solution
posted on Nov 25, 2009
Very Helpful)
Dnor350
Rank: Master
Rating: 100%, 5 votes
On the signal board there is 4 surface mount transistors. There is one right by the input board (BA09), i would check the corresponding caps and diodes close to it also. I would replace all of the 4 transistors. If this SMT starts to go you will see wavy lines in your picture than it will go away in 3 min or so and get worse over time until no picture is seen. When it totally fails you will have no inputs what soever but you will have an OSD screen and when you choose DTV you will get a scrolling picture.
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Mitsubishi WS-55513 55 in.
Questions and Unsolved Problems for Mitsubishi WS-55513 55 in.
Do you recommend Mitsubishi WS-55513 55 in. Rear Projection HDTV Television?
Answer
Answer
green flashing light will not stop .... even after reset button is pushed....have tried unplugging... (More)
Answer
the timer light will not stop blinking even after resetting as indicated in the owners manual,my set... (More)
Answer
tv will not come on - when the power button is pressed the green light begins to blink- then the... (More)
Answer
won't turn on, no sound, no picture. The green light stays on in front at all times until we unplug... (More)
Answer
All of a sudden the picture seems darker then it should be.. I went to the video menu and tried to... (More)
Describe your Projection Televisions problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Projection... Experts
Top TV Repairmen
(316) 283-8873
(316) 838-0811
Authorized Warranty On Rca,Integrity In Sales...
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
