Question about Nintendo Game Boy Advance Console
How do you get the mad catz ps3 wireless controller to work?
When switched on all 4 lights are flashing simultaniously,
How do we get it to configure with the ps3?
  • Anonymous Apr 28, 2008
    tried just about everything , every button togerher ,seprate, nothing
Throw it up against the wall....thats what i did...(if it doesnt work fixed...maybe it works broken)...burninmicz@yahoo
Posted on Jul 22, 2008
I have a madcatz call of duty black ops controll, it charges when i connect it but wont connect to my ps3? help me!
You need to sync your controller with the ps3, put the USB dongle into one of the available slots on the ps3 - exactly where you would normally connect a wired controller on the front. Now switch on your ps3, the dongle will connect, now put your USB cable into the black ops controller and switch on - your 4 lights should be flashing on the controller. Now press connect on the USB dongle, your controller should now sync to the ps3 and hopefully will show as controller No 1. Remove the USB cable and play wireless.
Jul 13, 2012 | Mad Catz Call of Duty Black Ops...
My mad catz controller will not configure to my ps3.How can i do it wireless?
sir good day there are two way on how to configure your wireless controller to your ps3 console.... the automatic pairing and a manual pairing
first way an automatic pairing
1.turn on your ps3..
2.Connect the smaller end of the included USB cable to the PS3 controller.
3.Connect the opposite end into either USB port on the front of the PS3.
The pair light on the PS3 will flash. When it stabilizes, you can disconnect the USB cable
and use the controller wirelessly.
second way a manual pairing
1.. turn your ps3..
3.Connect the opposite end into either USB port on the front of the PS3. Press the "PS" button on the center of the PS3 controller. The pair light on the controller will flash. When it stabilizes, you can disconnect the USB cable and use the controller wirelessly.
you can try that 2 way on how to configure your controller to your ps3 console if this help you please rate me thank you sir..
Jun 12, 2011 | Mad Catz Call of Duty Black Ops...
I HAVE A GAMEWARE PS3 CONTROLLER BUT HAVE LOST THE INSTRUCTIONS HOW TO ASSIGN TO PS3. PLEASE ADVISE
  1. turn on PS3
  2. Press HOME on GamePad - 4 channel indicators flashing slowly
  3. Press FC on Gamepad - 4 channel indicators flashing quickly
  4. Plug the receiver into the USB port on PS3 - 4 channel indicators flshing slowly
  5. Press HOME on Gamepad, one active channel LED indicator will light up
Jan 08, 2011 | Cameras
My ps3 will not stay turned on when i do try to turn it on its light turns to a yellowish color and then starts flashing red like it's off but it stays flashing unless you turn off the switch
The PS3 Yellow Light is the 360's cousin for the Red Ring of Death. My assumption is that you may have unintentionally blocked any sort of cooling the PS3 has. Here are some steps in correcting that yellow light. This information comes from HowtoFixyourPS3.com:
In order to fix your PS3 yellow light error, there are 3 things that you can do.
1 - Restart your Playstation 3.
2 - Check for loose cables.
3 - Unplug all cables, and plug them back in.
4 - Take out your hard-drive, and place it back in your console.
If these 4 tips didn't fix the PS3 yellow light problem, then it's high likely that there's something wrong with your hardware. In order to repair that problem, you can do 2 things. You either send your console over to Sony. Or, you simply fix the problem yourself while using a PS3 repair guide.
Jan 01, 2011 | Video Game Consoles & Games
How to fix ps3 when light flashes green,yellow, then red
Turn on TV and set input to port being used.
2 - Make sure PS3 is connected via correct cable.
3 - Power on PS3 via power button and HOLD IT for 5 seconds (release after the second beep). It should automatically configure your PS3 to the TV's native resolution for all settings.hello
regards
shaun
Jul 29, 2010 | Sony Playstation 3 (PS3) Console
Red light flashes on PS3 and won't switch on , how can I fix this ?
i need to ask is it a slim or a ps3 with 4 usb ports?
if its a slim there is 2 ways
1. click the buttom
2. press the middle button on your ps3 controller
if its not a slim there is still 2 ways
1 . slide you finger across the power on the ps3
2. middle button on controller
Hoper i hellped ^^
Apr 15, 2010 | Sony Playstation 3 (PS3) Console
How i can fix red screen on ps3 ?
Well first of all you can try the below steps -
1. turn off your ps3 with switch at back
2.hold power button
3.(do this while holding pwr button) switch back on the ps3
4. if done correctly the ps3 should make a loud fan noise causing the fans to enhance for awhile, that should clean out anything that could overheat the ps3
Sometimes the red light will be flashing because there is a problem with the connection of the hard drive to the rest of the PS3 or the hard drive itself is broken.
You can usually fix this problem by re-setting the drive. To do this, go to the side of your console and take out the hard drive. Then replace it in exactly the same position. If the red light is still flashing when you turn your PS3 on, you might have to get a new hard drive, or even a new PS3. Please post comments for more help or information..........
Good Luck!!
Thanks
Mar 01, 2010 | Sony Playstation 3 (PS3) Console
My ps3 keeps saying ne detected controllers when one is plugged in, there are 4 red lights flasing on the controller which is plugged into the console, after 20 minutes still no controller detected, any...
You need to press the ps switch and see if it says charging.When the lights flash on the controller it means they are charging the batteries.
The only way I know of to fix this problem is to switch off the PS3 from the switch in the back.Then turn it back on.The PS3 will assign the controllers.
Aug 01, 2009 | Sony Playstation 3 (PS3) Console
How to set up yobo controllers for ps3
I just bought a used one today and took me a little while to get it to work. Plug the USB receiver in and turn on the PS3. Press the Mode button and the lights will flash repeatedly at a fast rate (it's searching for the receiver). When it finds the USB receiver, the lights will still flash, but slower than before. When they're doing this, press the mode button again, and that should be all that you have to do. You can also plug the receiver in USB slot one, the charge cable in slot 2, and do the steps to set it up to make it work while charging. (I tried taking the receiver out while charging, and the lights started flashing again so I guess the USB receiver has to be in at all times)
Jan 11, 2009 | YOBO FC Game Console
Nintendo Game Boy Advance Console Logo
Top Nintendo Video Game Consoles & Games Experts
Raj Patel
Julian Wainwright
Martin Murray
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
