Question about Frigidaire GLTF2940ES Front Load Washer
Washer doesn't drain the water out
My wash machine ony drains once in while and doesn't spin what is going on with it? I cleaned the drain hose and check if it was plugged and that wasn't the problem. Can you tell me what it is?
The wash machine will not drain the water out. I have taken the hose off and it is clear and not kinked. It looks like the little drain motor on bottom by the hose connections is not working. I take some of the water out and it will spin but there does not seem to be any suction so the water does not go into the drain hose. The water seems to stay in the big hose under drum section before the little motor. I read in the manual that there was a safety switch some where. Could this be it? Where is it?
    Sergeant:
  • 274 Answers
Your pump is no good any more you need a new one
Posted on Jan 05, 2008
6ya staff
SOURCE:
I have a Whirlpool Ultimate Care II washing machine (model LSN1000JQ0). The washer will fill with water and begin to agitate. Shortly after it will stop and will not drain. I've cleaned all hoses
see the next steps and use the common sense: God bless you
It spins, but doesn't pump If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing can get between the clothes tub and the outer tub that holds the water. If the clothing gets between the tubs, it may then get into the drain hose that's attached to the pump--or even into the pump itself. If it's in the pump, you need to remove the hoses from the pump and pull the item out. To remove the sock from the outer tub port, open the washer's main access panel and remove the large-diameter rubber hose that connects the pump to the bottom of the outer tub. Then, using needle-nose pliers, try to grab and remove the clothing through the port. Sometimes you can't remove the stuck clothing from below. Then you have to remove the agitator, top of the outer drum shield, and inner clothes tub. This isn't easy to do--and you may need special tools--so you might be happier getting a qualified appliance repair technician to do the job. If the drain line isn't plugged, the problem may be with your pump. Even if the pump appears to be turning, the internal impeller may be broken. If so, you need to replace the pump. It doesn't spin or pump If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it. It pumps, but the water returns If the water that pumps out of the machine goes back into the machine after the spin cycle, your washer may be siphoning the water from a laundry tub that has a slow drain, back into the washer. The usual remedy for this is to improve the draining of the laundry tub. (Is something stuck in the drain?) Also, check for these problems: If the drain hose reaches more than about 4 inches into the laundry tub, cut off the excess. If your drain hose is lower than the washer's cabinet, install an air gap/siphon break assembly.
Aug 01, 2012 | Whirlpool Ultimate Care II LSQ9564J Top...
Spin cycle doesn't work.
Hello.
Here are names of tools and instruction below to solve theproblem
  • Screwdrivers,Flashlight,Voltmeter,Wrenches,Bucket,Rags or mop
There are several reasons that a washing machine won't drainor spin. The cause could be something as easy as a clog or something difficultthat will need a licensed repairman. Start with the simplest possible cause andwork down to the more difficult causes. ·1A washing machine won't spin if the water can't drain. Check hoses for anykinks or clogs that may prevent the water from draining. If a hose has kinks,try to straighten out the kinked hose. If it can't be straighten sufficiently,replace the hose. If hoses are not kinked, check for clogged hoses. This can bedone by using the screwdrivers to remove the hoses and looking for clogs orrunning a water hose through the clogged hose to remove the clog. Use the ragsand bucket to clean up the water that comes out of the hoses when they are disconnected.Once the clog is cleared, put the drain hose back into place. The washer shoulddrain and spin now if a clogged or kinked hose was the problem. ·2 If the washer still won't drain or spin, checkto see if the lid is not closing all the way or if the lid switch is notclicking into place. Close the lid and make sure that it closes all the waydown. When the lid closes, the lid switch should click. If there is no clickingsound, then the switch may need to be replaced. Follow manufacturer's directionsfor replacing the switch. If the lid does not close all the way, visually checkfor signs that the lid is bent. If bent, try to bend it back into place. ·3 Loose or broken belts could also prevent awashing machine from draining or spinning. Pull the washer away from the walland, using the screwdrivers and wrenches, remove the back panel. Using theflashlight, visually check for any broken or loose belts. Replace any broken orloose belts. Although replacing washing machine belts is difficult, anyone whohas replaced belts on a car, lawn mower or even a bicycle chain should be ableto accomplish the task. ·4 Another possibility for a washing machine tonot spin or drain is the pump. With the back panel still off the washer, checkthe pump with the voltmeter to ensure that the pump is getting power. If thewasher is getting power, turn on the washer and listen to find out if the pumpis running but the water is still not draining. It may be necessary to removethe pump and clean it or to replace the pump with a new one. Once the pump isreplaced, turn on the washer to determine if it will now drain and spin. ·5 If all of the above steps fail to produce awashing machine that drains or spins, then it is time to call a professionalrepairman. Use the screwdrivers and wrenches to replace the panel on the washerand push it back against the wall.Thanks for using fixya.
Sep 06, 2011 | Maytag Neptune Washer
Frididaire washer error 10 Washer will take in water but doesn't spin or complete cycle. Doesn't let water out.
Hello.
When Washing Machines electronic control has detected a condition then it indicate by showinh error code which needs to check. When you see a code, follow these steps to solve the problem.
However, there are several reasons that a washing machine won't drain or spin. The cause could be something as easy as a clog or something difficult that will need a licensed repairman. Start with the simplest possible cause and work down to the more difficult causes.
Challenging Instructions And Things You'll Need:
· Screwdriver,Flashlight,Voltmeter,Wrenches,Bucket,Rags or mop.
  1. A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
  2. If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced. Follow manufacturer's directions for replacing the switch. If the lid does not close all the way, visually check for signs that the lid is bent. If bent, try to bend it back into place.
  3. Loose or broken belts could also prevent a washing machine from draining or spinning. Pull the washer away from the wall and, using the screwdrivers and wrenches, remove the back panel. Using the flashlight, visually check for any broken or loose belts. Replace any broken or loose belts. Although replacing washing machine belts is difficult, anyone who has replaced belts on a car , lawn mower or even a bicycle chain should be able to accomplish the task.
  4. Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin.
  5. If all of the above steps fail to produce a washing machine that drains or spins, then it is time to call a professional repairman. Use the screwdrivers and wrenches to replace the panel on the washer and push it back against the wall.
Aug 02, 2011 | Washing Machines
Washing machine wont spin and is full of water and wont drain
  1. 1 A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem.
  2. 2 If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced. Follow manufacturer's directions for replacing the switch. If the lid does not close all the way, visually check for signs that the lid is bent. If bent, try to bend it back into place.
  3. 3 Loose or broken belts could also prevent a washing machine from draining or spinning. Pull the washer away from the wall and, using the screwdrivers and wrenches, remove the back panel. Using the flashlight, visually check for any broken or loose belts. Replace any broken or loose belts. Although replacing washing machine belts is difficult, anyone who has replaced belts on a car, lawn mower or even a bicycle chain should be able to accomplish the task.
  4. 4 Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin.
  5. 5 If all of the above steps fail to produce a washing machine that drains or spins, then it is time to call a professional repairman. Use the screwdrivers and wrenches to replace the panel on the washer and push it back against the wall.
May 31, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Water wont drain out
1)A washing machine won't spin if the water can't drain. Check hoses for any kinks or clogs that may prevent the water from draining. If a hose has kinks, try to straighten out the kinked hose. If it can't be straighten sufficiently, replace the hose. If hoses are not kinked, check for clogged hoses. This can be done by using the screwdrivers to remove the hoses and looking for clogs or running a water hose through the clogged hose to remove the clog. Use the rags and bucket to clean up the water that comes out of the hoses when they are disconnected. Once the clog is cleared, put the drain hose back into place. The washer should drain and spin now if a clogged or kinked hose was the problem
2)If the washer still won't drain or spin, check to see if the lid is not closing all the way or if the lid switch is not clicking into place. Close the lid and make sure that it closes all the way down. When the lid closes, the lid switch should click. If there is no clicking sound, then the switch may need to be replaced. Follow manufacturer's directions for replacing the switch. If the lid does not close all the way, visually check for signs that the lid is bent. If bent, try to bend it back into place.
3)Another possibility for a washing machine to not spin or drain is the pump. With the back panel still off the washer, check the pump with the voltmeter to ensure that the pump is getting power. If the washer is getting power, turn on the washer and listen to find out if the pump is running but the water is still not draining. It may be necessary to remove the pump and clean it or to replace the pump with a new one. Once the pump is replaced, turn on the washer to determine if it will now drain and spin.
If all of the above steps fail to produce a washing machine that drains, then it is time to call a professional repairman.
Thank you !!
May 25, 2010 | General Electric WSSH300G Front Load...
My washing machine wont drain or do the final spin.
May 20, 2010 | Frigidaire ATF6000ES Front Load Washer
Water not draining during spin cycle - softener not dispensing into rinse cycle
Just make out the following checks before calling a repairman.
Aug 30, 2009 | Amana Washing Machines
Washer does not remove water in final spin
If washer hums when it should spin, and the washer will not drain, you may have 2 issues.
First check that the drain pump, drain hose, and wall drain are free of debris.
The washer may not spin properly if the drain system is not operable.
Once you are sure the washer drain pump, drain lines, wall drain, and drain hose is okay, run a test wash.
If the washer hums but now drains, you fixed one issue.
If the washer still hums, you may have a bad belt, motor coupler, motor itself, etc...
Check parts for wear and replace as necessary.I pulled the drain impeller and found a sock from my little guy stuck in there. Fixed!
check all water outlets to make sure there is nothing blocking the pipes.
you could also go to this link it might help you out..... Washer does not remove water in final spin Google Search
Oct 24, 2017 | Maytag MAH6700AWW Neptune Front-Load...
Power off the wall; open up behind your machine, check to see if the belt is tight. Possible it has come off...........
Dec 26, 2007 | Frigidaire GLTF1670A Front Load Washer
Frigidaire GLTF2940ES Front Load Washer Logo
41 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
Archie Ferrarini
Archie Ferrarini
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
