Home | HP | OfficeJet 7310 All-In-One InkJet Printer | My 7310 printer tel...
HP OfficeJet 7310 All-In-One InkJet Printer
Problem for HP OfficeJet 7310 All-In-One InkJet Printer
My 7310 printer tells me it has an alignment
By trent_rushin on Nov 07, 2009
my 7310 printer tells me it has an alignment failure. I have turned machine on and off. Done the printer service features and it is not
better.
Any ideas?
Solution #1
posted on Nov 07, 2009
Not Rated)
tanmoy_ra138
Rank: Master
Rating: 91%, 4 votes
1.u can uninstall the cartridges
2.take the power cable out from the back of the printer
3.press and hold "#" & "6" key while the power cable is out
4.while pressing both the keys plug the power cable in and try to connect the printer directly to wall outlet
5.release both the keys, u will see ur printer will turn on automatically, if it does not press the power botton and turn it on , then it ask for the language press 11
6.ur printer will start making noise so do not worry abt that and it will ask for the cartridges,
7.install the cartridges
8.when u get ur normal screen of the printer then check the performance
Was this helpful?
Yes
No
Popular Solutions for HP OfficeJet 7310 All-In-One
Questions and Unsolved Problems for HP OfficeJet 7310 All-In-One
Do you recommend HP OfficeJet 7310 All-In-One InkJet Printer?
Answer
Answer
i replaced my print cartriges, at first it stated the color ink was bad, so I replaced it again and... (More)
Answer
Remove display "Genuine HP Print Cartridge installed" every time I print -- 3 display... (More)
Answer
(This software cannot be installed using the 'Run as...' command. The installation cannot continue... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For HP OfficeJet 7310 All-In-One...:
Top Printer Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
