My Mitsubishi wd-62525 tuner does not pick any tv signals.I turn the tv on tonight and got no picture be it hd or sd. pushed the reset button and still nothing. unplugged it over night and nothing changed, so I did a channel scan and no results. What's the problem? Is it worth fixing?
Probably not, however if you have a VCR you can use the A/V outputs and plug those into the A/V input of the TV then switch your TV to AV 1 and watch TV that way if you don't want to have it repaired. The RCA video cables only cost about $7.00, Home Depot or any electronics store will have them.
I have a Mitsubishi WD-52525 and when i plug anything into inputs 1,2,or 3 the screen will start off...
(More)
I have a Mitsubishi WD-52525 and when i plug anything into inputs 1,2,or 3 the screen will start off fine but slow start flickering with bars going across (regardless of what is plug in). When I plug something into the HDMI outlet the audio is full of static.
Blazz I am trying to get the info youre requesting to help you repair your WD52525 but I keep...
(More)
Blazz I am trying to get the info youre requesting to help you repair your WD52525 but I keep getting locked out so I cant respond to your questions. slinteriors
