Question about Compaq Presario SR1050NX (DW257A) PC Desktop
Compaq Auto Boot
My friend's compaq automatically turns on during the night, sometimes 2 or 3 times. Not always at the same time - except 3am seems to be the norm. How can I stop this? However, I don't know the exact model (I do not believe it is the SR1050 but I couldn't find anything on the posts closer).
I appreciate your help! Thanks!!
  • Robin_Lynn Jan 07, 2008
    I checked power options and viruses already, sorry I didn't mention it.
    What do you mean check CPU, temp, power supply, ram, hdd?
  • 1,006 Answers
Can be to much reason but we will try one by one
1)Go to control panel and check the POWER OPTIONS
2)Infected with VIRUS
3)CHeck CPU temperature,POWER SUPLY.RAM.HDD!
Posted on Jan 05, 2008
Compaq presario has fedora needs to get back to windows 7
What you need to do is put in the first restore disc. Turn off the PC. Then when you start you will see the compaq logo there should be an option to boot to boot order. Usually F12. If not there should be an option to go to BIOS. F2. You need to boot to disc first. Once you boot to disc follow the instructions to reinstall Windows.
Jan 19, 2013 | Compaq Presario CQ56-115DX Laptop
Compaq nc6220 freezes during POST
Start in Safe Mode by pressing F8 during boot. Then...
Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig > Startup tab and uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running.
This just disables them in startup. Programs will still load, but when you initiate.
Oct 04, 2012 | HP Compaq nc6220 Notebook
Good night, i formated the hdd of my compaq armada 1500c, next i install win xp sp2, every time that the computer boot, i see a mesage that says system date and time not set. how can i restore the bios...
There is not a bios partition, as the bios is a firmware on the mother board. You need to press the key specified early during boot up, before the system seeks the hd for load.
Oct 02, 2010 | Compaq Armada 1500C Notebook
Compaq Presario V4215EA won't boot, switches off by self
sorry dude, this seems like a prone problem on your own PC, this is what you do lete a PC engineer check it out. or if it is still on waranty return it. good luck
Aug 28, 2009 | Compaq Presario V4000 Notebook
3 different things may happen when i turn comp on
Im wondering if the hard drive is beginning to go bad, that would cause lockups and also cause it to hang on the compaq logo screen.
It could also be the start of the motherboard going bad. Take your hard drive out, put a good known working one in there and with your discs, restore your laptop with the known good working hard drive and then see what happens, if the lockups are still happening then you know the motherboard is going bad.
May 23, 2009 | HP Compaq Presario V6000T Notebook
Auto shut down problems
Check your Processor FAN and Heatsink lock if the heatsink firmly sit tight on your processor, sometimes the heatsink lock is lossen making the processor extremely heat and shutdowns automatically, if its ok, then try replacing your powersupply.
Jun 11, 2008 | Compaq Presario 5000 PC Desktop
Please help - it's possessed!
Click HERE for an explanation of beep codes
May 24, 2008 | Compaq Armada E500 Notebook
Trouble starting compaq presario F551AU
Hey I apoligise for the late reply,
Ok, first off when you turn off the computer without shutting down, windws does not get enough time to wirte necessary data to the disc, this does not always cause aproblem because sometimes there are unpredictable events such as power failure..
You might need to format your hardrive to fix this problem
To do this boot with the windows cd, it will say press any key to boot from disc. (YOU MIGHT NEED TO SET YOUR BOOT DEVICE IN THE BIOS(SETUP))
anyway fisrt off try a fresh install, leaving your current file system intact. Id that works then you will still have all your data on your disc, If not then you need to do a complete format.. Good Luck
Dec 29, 2007 | Compaq 20GB NOTEBOOK HARD DRIVE KIT FOR...
Frozen during boot-up, keyboard still works
Sounds like the PC is running into a hardware failure and the Compaq splash screen is probably hiding some additional information. It?s been a long time since I've owned a Compaq, however, what you need to do first is eliminate the Compaq screen to show us whatever boot details it may be hiding. I seem to recall on my old Compaq (and most Dells) I had to disable the Compaq screen in the BIOS settings. Hitting the F10 key as soon as the Compaq screen appears I believe will get you into the BIOS program, however, be warned if you change anything in there by accident you will be causing yourself a world of trouble. After you get into there you want to look for the Boot selection of the menu. In there somewhere will be a setting referring to something similar to ?reveal boot details? or hide splash or Compaq screen?. If it isn?t obvious let me know, I?ll have access to an older Compaq with a similar BIOS and can give you more details. If you are able to disable the splash screen reboot the PC and watch for errors. Based on the age of the machine and past history I suspect you?ll find a boot disk or read error.
Nov 28, 2006 | Compaq Presario 5716 PC Desktop
My Compac Armada M700 does not power up.
Had the same problem with My Compaq M700 No Boot Or Post. Battery Light Flashes 8 Times, Have to Wait 24 to 48 hrs sometimes longer to get Laptop to Start. Tryed the DC Converter Board Change No Difference same Problem. Noticed When Laptop Did Start Clock Time Was always a Little Off 2-4 Hours sometimes more. So Figure CMOS Problem With Time Issues. Read About Battery Memory Transitor Voltage spike Detection Issues Corrected With Newer Bios Flash at HP Supports. So I Flashed Bios With Latest 686h. During the First Boot After Reflash Battery LED Did flash No Start, After pushing the power button again it Started. And has Every since.So Far Laptop Now Boots Everytime and CMOS Checksum Seems To Keep Time Correct In Windows. The Bios Flash Corrects a Voltage Spike Detecting Transistor In The Charging Circuit. During First Start after flash Bios will run system test on the charging system and Correct CMOS. Worked for Me Hope this Helps a Few.
Oct 30, 2006 | Compaq Armada M700 Notebook
Compaq Presario SR1050NX (DW257A) PC Desktop Logo
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
