Question about NetGear DG834G Router
Netgear 834 cant connect ipod touch to netgear,when router isdisabled ipod goes on line am on wep key thanks
Changed wep to wpa.ipod works great
regards
Posted on Feb 22, 2008
    Problem Solver:
  • 18 Answers
Do ur self a favor.... disable the security on ur router.192.168.0.1
user :admin
password: password
you can change ur user name and password to lock out ur neighbor. But you don't need to enable WEP OR WPA.
doing this should take care of ur ipod touch connection.
Posted on Feb 20, 2008
Can't connect ipod touch to it
Hello
You will need to enter the wireless wep or wireless code into the ipod.
Log onto your routers homepage using 192.168.1.0 or 192.168.1.1
Once there find your wireless settings and copy the code onto the i pod.
Do this in the network settings page of the i pod.You will need to register your i pod at i tunes.
Thanks.
Jan 22, 2010 | NetGear DG834G Router
I cant get my ipod hooked up to my roter and wii
This is first assuming you are talking about an IPOD Touch. You first have to have wireless connectivity. Once you have wifi go to:
1. Touch Settings
2. Touch Wifi
3. Turn your Wifi ON
4. Select a Wifi network
5. Enter the WEP Key you have created on your router (assuming you have secured your network).
6. Hit Connect
Jan 20, 2010 | Linksys Wireless-G Broadband Router
Where is my WEP key
Take a notebook or desktop computer, and connect it to the router.
Access the router's built-in web-server, and query or set the WEP
(Wired-Equivalent Protocol) key.
Then, on the iPod Touch, enter the value of the key.
Jan 09, 2010 | NetGear WGR614 Wireless Router
Connecting my ipod touch to my wireless router through wi fi
Check for the password on the router configuration page to make sure tat you are using the correct one:
1. Open the browser(Internet Explorer or Mozilla Firefox).
2. Access the router usually http://192.168.0.1 else try http://www.routerlogin.com
3. Login to the router (User Name = admin Password = password unless you have changed it).
4. Click on Wireless Settings'(under Setup) from the left menu.
5. Check if 'WEP (Wired Equivalent Privacy)' or 'WPA-PSK (Wi-Fi Protected Access Pre-Shared Key)' is selected under 'Security Options'.
6. If WPA-PSK is selected, copy the code entered in the passphrase.
7. If WEP is selected, copy the code entered in the Key that has a black dot before it.
This is the code required for connecting the wireless computer to the routers' wireless network.
Enter the same password on IPOD to connect to the wireless network.
Rate it,if it helps.
Jun 25, 2009 | NetGear DG834G Router
My PS3 cant find IP address from Netgear router DG 834,what I have to do
make sure you are putting the network key correctly...if you dont know tha network key.. try the following.. . Connect a computer to the router using any one of the 4 available ports.
2. Open the browser (Internet Explorer, Mozilla Firefox or Safari).
3. Access the router usually by typing 'http://192.168.0.1' or 'http://www.routerlogin.com' in the address bar.
4. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
Click on wireless settings (under setup) from left menu.
Change the channel to 11
*-security option > select wep.. in KEY 1 put a ten digit number .... nothing under passphrase ..
Apply settings to save the changes.
*-then try to connect your PS 3
I hope the steps above will help resolve the issue. If you need any further help, please email us back so that we can continue to work on a solution.
I hope this information allows you to resolve this issue.
Jun 14, 2009 | NetGear DG834G Router
My ipod touch has recognised the wireless networks and when i type the passwords in it sais cannot connect to network... any suggestions it is a netgear router
when it attempts to connect to your network, it is asking for the wep key
which is located on the bottom label of your wireless router.
look on your router and write down the wep key.
attempt to connect again and enter that key.
also go to settings and make sure you attempting to log into your wireless not your neighbors.
your network identifier should be on your router also.
if this helps please leave a vote in fixya
Apr 17, 2009 | Apple iPod touch
Unable to connect to wifi network on ipod 2g touch
You must have your wireless profile's name and passkey.  Try resetting your router, then make sure you create a new profile for your desktop and take note of the details (ie name, WEP/WPA Key)  Should work just fine if you follow the steps.
Feb 14, 2009 | Apple iPod touch
Cant connect!!
Call your ISP service and talk to a tekkie They answer I pod log on problems all the time they resolved mine pretty quick
Dec 27, 2008 | NetGear DG834G Router
Lost network password which I need to sign on an ipod touch using a netgear dg834gt
Key 1 should work in most cases. If you have additional keys listed, try them also.
If none work, turn off encryption and connect your new device, then create a new password.
The manual page is here:
http://kbserver.netgear.com/kb_web_files/n101675.asp
Nov 19, 2007 | Computers & Internet
Connecting Ipod touch 8(GB) to Wi-fi
After fighting with this for the last couple of hours I have my ipod touch working with the netgear DG834G(v3) router. The fix is a bit odd and I am not entirely sure why it works but I thought I would share and hopefully it might help you out …
First I think that the WEP encryption simply does not work between these two devices and causes some very strange behaviour – the WEP 'authentication type' setting I had on the 'wireless settings' page was set to 'shared key' – I flicked this to 'automatic' & strength to ‘128 bit’ - hit apply and finally I found I was able to connect without an error message (after inputting the correct WEP key). Unfortunately the DHCP did not work correctly after this and I kept receiving IP addresses in the range of 169.254.x.x (an internal default) rather than my networks expected 192.168.0.x range. The Ipod touch couldn’t find any DNS servers or connect to the internet.
To get round this I set the router ‘security options’ to use WPA instead (WPA-PSK (Wi-Fi Protected Access Pre-Shared Key)) instead of WEP. Set the new WPA password at the bottom of the wireless settings page - again hit apply - and configured the ipod to use the new password and WPA PSK instead of WEP. This worked fine – although it does mean I have to change the settings on all my other wireless devices around the house!
The weird thing is that although the router isn’t using WEP encryption changing the 'authentication type' setting back to ‘shared key’ in the WEP menu breaks the WPA connection again – very odd? I blame netgear and their obviously crazy wep code :)
Nov 04, 2007 | NetGear DG834G Router
NetGear DG834G Router Logo
323 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
