Question about Casio EXILIM ZOOM EX-Z60 Digital Camera
The lens on my camera won't retract.
I believe my camera was dropped by a friend a few days ago while the lens was out. and now a few seconds after turning on the camera, it will turn off by itself, and it will not retract the lens. I can't take pics or do nothing, and I know the battery is fully charged. Any suggestions?
  • Casio Master
  • 4,738 Answers
The following blog outlines some repair options for a lens error. They won't work for all cases, but they're worth a try if the camera's no longer under warranty:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Posted on Jan 05, 2008
If i on the camera the lens won't work properly and message that turn off the camera and turn on again
Hi there:
If the camera has recently been dropped it may have lens damage that is preventing it from powering up. There are a number of ways with which a lens error can be caused. Particulates might have managed to get into the mechanical bits that allow the lens to retract, a purely physical interference with the lens mechanism. If the camera was dropped, especially while the lens was extended, there's a pretty good chance something might have been knocked loose, such as the guide pins upon which the lens withdraws and retracts.
Additional details could find in this article link: fixing-lens-error-on-digital-camera.html
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using FixYa, have a nice day.
Aug 22, 2012 | Sony Cyber-shot DSC-W170 Digital Camera
I have a Canon IXUS970IS and the lens is stuck 3/4 out. I do not know how it happened as I loaned the camera out and it came back like this. I am told it just happened. There is no evidence that the...
I will say with 95% certainty the camera was dropped while the lens was extended. It does not take much of an impact to make the Canon lenses lock up, a very small drop, or even banging the lens into a door or something while it is extended will do this. It happened to my Canon, and two other friends' Canon cameras as well! Googling the issue also shows how common this is. I had my camera hanging around my neck and merely bumped my extended lens while opening a door. The gears inside are SO fine, and it skips just one tooth and it will fail. It sucks.
Sending the camera in to Canon for repair seems to be the only option, since you already tried gently push/pull/twist of the lens while it tries to retract. That worked for one friend, I sent mine into Canon for $50 repair.
Sorry.
Sep 08, 2011 | Canon PowerShot SD890 IS / IXUS 970 IS...
A few weeks ago, shortly after I'd taken a pic, the lens refused to retract and the camera switched off. It has never been dropped or had anything spilled on it. Strangely, when I press the button...
Sounds like a lens error. Look for sand particles around the gaps of the lens barrel (a single particle can jam it). Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Here are some troubleshooting steps that you can try that may (or may not) correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty (or repair cost approaches that of the camera), they're worth that try. Some of the later steps do involve some risk to the camera, so carefully weigh your options before deciding to conduct them:
Jul 31, 2011 | Kodak EasyShare V1003 Digital Camera
Pentax Optio S10 - Turning on problem
What kind of shape is your battery in?...old, been charged many times, needs charged, dirty contacts on the battery or inside the camera?
Sep 17, 2009 | Pentax Optio S10 Digital Camera
Lens won't retract
There are special springs, motors, gears, and guides inside these lenses.
If your lens won't retract, one of the above is bent, misaligned, or broken. There is not a 'quick fix' that can be applied in your situation since it is a physical problem, not a software malfunction. You can try to dismantle yourself but speaking from experience you are likely to make the problem worse. If you are unwilling to attempt repari yourself, either take it to a repair shop or upgrade.
Aug 18, 2009 | Cameras
Samsung s700 camera lens won't retract
you must have dropped your camera where it caused damage in internal part. when cameras are dropped wires and screws inside loosen which will cause trouble. Have it checked by a pro. you might destroy it more if you try to fix it yourself. Thanks.
Nov 15, 2008 | Samsung Digimax S700 Digital Camera
Kodak V1003
Hello!!!
please remove your batteries and press the power button for few seconds and replace the batteries now and try switching on ...
Regards
Smilemaker.
Jul 19, 2008 | Kodak EasyShare V1003 Digital Camera
Lens won't retract
Here is a link to troubleshoot your issue. I hope this solves your problem. http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00596002&cc=us&lc=en&dlc=en&product=1147733&dlc=en&lang=en
Aug 25, 2007 | HP Photosmart M425 Digital Camera
My lens :[[
Hopefully someone has a better answer, but no mater what mode its in, its been my experience these cameras don't like to be dropped. Sometimes they can be repaired, its just a matter of finding someone who or return camera to factory for a repair.
Apr 29, 2007 | Olympus Stylus 810 Digital Camera
Casio EXILIM ZOOM EX-Z60 Digital Camera Logo
101 people viewed this question
Top Casio Cameras Experts
Greg Cann
Greg Cann
mohamed salim shaikh
Are you a Casio Camera Expert? Answer questions, earn points and help others
