Ricoh Aficio 1035 Grayscale Copier
Problem for Ricoh Aficio 1035 Grayscale Copier
Do i need to setting something after reinstall the
By nazri_98 on Nov 07, 2009
do i need to setting something after reinstall the pcu?
Comments:
Nov 10, 2009
- Thanks....i will try the suggestion.!
Solution #1
posted on Nov 08, 2009
Not Rated)
copydoki
Rank: Wiz  Ricoh Office Equipment  Expert
Rating: 81%, 119 votes
If you install a new pcu perform the ID sensor initial setting using SP 3001002,do the process initial setting prosedure SP 2805.After replacing the charge roller and cleaning roller check the value of SP2001001,if is not at the standard 1450V set SP 2001001 to the value.
Was this helpful?
Yes
No
Popular Solutions for Ricoh Aficio 1035 Grayscale
Questions and Unsolved Problems for Ricoh Aficio 1035 Grayscale
Do you recommend Ricoh Aficio 1035 Grayscale Copier?
Answer
Answer
Hi, How do I connect the Ricoh 1035 Grayscale Copier to my Toshiba laptop with a usb port?
Answer
scan message 'transmision to server has failed. data will transmit later
Answer
tell me how to use my printer as a network printer
Answer
connecting my ricoh mp2000 to a new computer with windows 7. I have downloaded all the drivers...... (More)
Answer
IR 1600 COPIER SHOW ERROR CODE 9 HOW CAN I SOLVE THIS?
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Ricoh Aficio 1035 Grayscale...:
Top Copier Experts
Rank: Guru Guru
Solutions: 746
Experience: More than 5 years attempt with printers, computers and all office equipment
Ask Me
Find more Copier Experts
Top Copier & Fax Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
