Question about Dell Axim X50v Pocket PC
Dell AXIM x50v won't start.
I hadn't charged it for over a month, maybe more. and now, at charging (over more than 4 hours), it won't start. the darker amber light twinkles when no USB connection has been made. if both electric power and USD connecion are plugged, the amber light keeps forever.
what should i do?
  • 1 more comment
  • puncici Feb 01, 2009
    same thing when battery is back on, beside the orange power light nothing happens, when battery is out on craddle everything is working.
    Solutions??
  • truyen Feb 27, 2009
    Everything you said, it worked for me, except the last part: It won't turn on with the battery!
    Help please
  • mickyd2k8 May 11, 2010
    I also have the same problem with the X50 where i can only get it to work on the cradle, as soon as I remove it from the cradle and try to run on battery it won't work tried soft hard reset, tried the reset in the cradle but nothing happens, can you confirm if you have a fix for this
  • 3 Answers
Note: The following is a quote of someone else: I had the same prob. Went to dell site and found this. Take out battery. Put the cover back on. Attach to cradle and turn on. While it is on, do a soft reset. Turn off, take it out of the cradle and put battery back on. Try turning on with battery only.
Know it worked for me except for the last part. when i replace the battery it won't run on...again. tell me what happens with you ^_^
Posted on Jan 13, 2008
6ya staff
SOURCE:
My dell axim pocket pc charges but will not turn on when i disconnect it from the usb cord
the same thing happen to me. Change your battery. I chaged mine with a new one and then it worked fine.
Sep 28, 2009 | Dell Axim X50v Pocket PC
Blue screen with dell logo??
This is usually called the "Blue Screen of Death" and the system tries to dump memory
See if you can Read any of the text which may detail the error
Try starting it in safe mode by tapping F8 every few seconds during startup
If it starts post back and i'll tell you how to use system restore
If it still fails then call in an Engineer
Oct 14, 2008 | Dell Axim X50v Pocket PC
Dell Axim X50v won't turn on after 6 months of no use
Perform a hard reset.
1. Hold the reset button on the back.
2. Hold the Power button down.
3. Release the reset button.
4. Release the Power button.
5. Press the Contacts button when prompted.
Hope this helps!
Ken Akiyama
Jul 03, 2008 | Dell Axim X50 Pocket PC
No charge
I bet the battery can't hold a charge anymore. Is that battery a replacable item?
Jun 10, 2008 | Dell Axim X50v Pocket PC
Power button flashing
Clean the battery connectors on both sides, so on your Axim and on your battery.
Also try to push the battery against the connectors, maybe put a sheet of paper between it or so.
Mar 28, 2008 | Dell Axim X50v Pocket PC
Dell Amix x50v
its your inbuilt battery that needs charging first. Give it time to complete and your main battery will get charged.
Mar 21, 2008 | Dell Axim X50 Pocket PC
Will not turn on
1)check the wire of your charger if it is good
2)check your battery
3)check the connection of the battery on your cellphone maybe there are some connection that are disconnected
4) In general check your power supply.
Jan 25, 2008 | Dell Axim X50 Pocket PC
Problems with extended battery
Try to check your phone if the battery connector having lost to contact the battery well. Or the problem came from your battery try to borrow from your friends battery to identify the problem.
Please rate me solved if you like my problem.
Best regards,
Philip
Nov 01, 2007 | Dell Axim X50v Pocket PC
Dell Axim X50v Pocket PC Logo
555 people viewed this question
Ekse
Clive
Clive
Alun Cox
