Home | Honeywell | Programmable Thermostat Heater | How do you switch my new...
Honeywell Programmable Thermostat Heater
Problem for Honeywell Programmable Thermostat Heater
How do you switch my new thermostat to celcius
By krashew on Nov 07, 2009
How do you switch my new thermostat to celcius RT230B
Solution #1
posted on Nov 07, 2009
Not Rated)
shastalaker7
Rank: Guru  Air Conditioners  Expert
Rating: 92%, 51 votes
This should be very easy to do.Normally, there is a switch to do this located behind the front cover. Just grasp it and pull it off to see if it is located there. Sometimes, you will have to go into the program and do this change. If you have the manual, this will help. Honeywell stats are top of the line. If you cant figure it out, make a call to a air conditioning wholesale parts house with the model # and they can also tell you.I am sure you will find the switch behind front cover. Sincerely,
Shastalaker7
Was this helpful?
Yes
No
Popular Solutions for Honeywell Programmable
Questions and Unsolved Problems for Honeywell Programmable
Do you recommend Honeywell Programmable Thermostat Heater?
Answer
Answer
I need help programming my home thermostat for heat
Answer
ideal boiler no heat to radiators but hot water still working
Answer
i have 5 wires yellow,blue,red,brown n white where does the blue n brown wire go
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Honeywell Programmable...:
Top Heater Experts
Rank: Guru Guru
Solutions: 1582
Experience: I run a Full-time Appliance Service Co.with HVAC/Auto Air Conditioning and Small Engine Service.
Ask Me
Find more Heater Experts
Top Heater Repair
(800) 905-9506
Traditional water heaters use a storage tank to...
Plumbing Key
(888) 448-9872
Nationwide plumbers where ever you need us any...
plumbingcoop
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
