Canon PowerShot SD1000 Digital Camera
Problem for Canon PowerShot SD1000 Digital Camera
While taking a photo snap, don't see the picture
By phpatel1 on Nov 07, 2009
While taking a photo snap, don't see the picture on the screen. Screen is black. Can see the old picture on preview mode without any problem
Solution #1
posted on Nov 08, 2009
Not Rated)
FinIlkka
Rank: Wiz  Cameras & Camcorders  Expert
Rating: 82%, 56 votes
You should see all your pictures on preview mode. To turn on your screen, go to settings and change the screen to 'on' or the after-shot-preview time to anything else than '0' or 'off'.
Having the screen off gives you longer battery life though.
Was this helpful?
Yes
No
Solution #2
posted on Nov 07, 2009
Not Rated)
t00nz
Rank: Guru  Canon Cameras & Camcorders  Expert
Rating: 91%, 2037 votes
Sounds like you might have accidentally pressed the DISP or DISPLAY button on the back of your camera. This manually turns the screen on and off to save batterie (you would then use the optical viewfinder in its place). Press this button once to see if it corrects the problem.
If the above didn't help, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
Was this helpful?
Yes
No
Popular Solutions for Canon PowerShot SD1000 Digital
Questions and Unsolved Problems for Canon PowerShot SD1000 Digital
Do you recommend Canon PowerShot SD1000 Digital Camera?
Answer
Answer
I can turn my sd1000 on, the flash works, everything works. The only thing is that I can't see... (More)
Answer
the flash goes off once, then it just won't work again. all the pics are over exposed when any... (More)
Answer
I need to find out how to get the driver/installer ( to install on my computor) Canon Digital Camera... (More)
Answer
When I try to take a picture with the flash on the camera will not take the picture. The orange... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Digital Cameras Experts
Top Camera & Camcorder Repairmen
(888) 435-5080
Worldwide AFFORDABLE digital camera repair &...
Digital Camera Repair and Parts: Darntoothysam.com
(214) 951-9731
Digital Camera repair and sales,trade,salvage.
Mikes digital camera repair
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
