Asrock K7S41 Motherboard
Problem for Asrock K7S41 Motherboard
I got a motherboard asrock and i am not getting a
By jwjgroenewal on Nov 07, 2009
i got a motherboard asrock and i am not getting a boot up nor a bios beep what could be the problem?
Best Solution
posted on Nov 07, 2009
Very Helpful)
bhagyavichar
Rank: Guru  Computer Components  Expert
Rating: 95%, 2484 votes
is it in warranty..?? if not..
do it if u r a professional..
check the following:
1) the cmos battery (above +3v)..replace with a standby n see..
2) remove/clean dust neatly..dust is non-uniform in nature n may cause jam/short circuitry/excess resistace n many more..resulting an increase in heat..
3) open the CPU Heat-Sink with fan out of the socket..put some "Heat Sink Compound" (available in local electronics chip level spare market) between the cpu/processor and the CPU Heat Sink *** fan..resit/fit it tightly in position..
4) the smps itself may b defective/faulty..check the outputs of smps viz. 0v (black~ground); +12v (yellow); +5v (red, green~ps-on, violet~pg & grey~sb); -12v (blue); -5v(white); +3.3v(orange)..
the 'oscillator and error amplifier ic', or pwm switching regulator circuit..look for defective protector-transformer/resistance(esp 4.7k)/mosfet..
5) ur main/mother board..see with a debug card for mb error..may b short..look for defective capacitors(esp above 1000mfd)/mosfets..go through the mb's south bridge n the circuit lie around atx connector....
..plz give higher priority to step1-4 (as listed above) CAREFULLY..
immediately contact ur system admin/vendor.
Was this helpful?
Yes
No
3 people thought this was helpful
Popular Solutions for Asrock K7S41 Motherboard
Questions and Unsolved Problems for Asrock K7S41 Motherboard
Do you recommend Asrock K7S41 Motherboard?
Answer
Answer
how do i find the motherboard # on a IBM Aptiva e 2270 computer?
Answer
system board, dev 001, err 91, fru 3610
Answer
plug at interner exployer doesn't make contact front plug on inspiron 530 i purchased 06/2009 i... (More)
Answer
blackberry 8100 trackball wont move up it just move from left to right and down
Answer
I need a manual for the Apache X58 machine. Help please.
Describe your Motherboards problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Motherboard Experts
Top Computer & Laptop Repairmen
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
