There are two ways to transfer your photos from phone to pc, either by blutooth or via usb data cable.
These two means of transferring files will need special software installed in your computer in order to make a connection between mobile phone and computer. The list below are softwares that you may install in your computer to get access with the files on your mobile phone.
basicly you need the data cable and the motorola software. you can most likely buy the software at the sametime when you buy the cable from the shop. if not its also available online.
Download first a PC Suite software in your computer. This software will let you access the system of your phone. In this software you can transfer files, videos, audios to your phone from computer and vice-versa.
Find on the intenet a PC SUITE software compatible for your mobile phone unit...Install this to your computer..
Pc suite is a software that your mobile phone will be using to communicate with your computer. With this you can transfer files from your computer to your phone and vice-versa..There are two ways to connect your pc and your phone..First, is via usb data cable, data cable usually comes with your phone when you purchase it.. If there is none, purchase one that is compatible with phone and install the driver that comes with it. Second, is via blutooth. blutooth is a usb device capable of wireless transfer of signals, you also will need to purchase it with its driver...Some laptops have built in blutooth, if you have one it will be easy for you to access your phone through your computer..
Run your PC SUITE software and pair the phone with your computer. When pairing is successful you can now transfer your files from your phone to your laptop
You didn.t mention if you have the software installed that is needed to access the phone via usb cable. Motorolla,.LG, Nokia and all the phones I have dealt with use their own proprietary software usually available from their respective web sites. The USB cable won't work without the phones software.
You need the USB driver for your phone as well as Motorola Phone Tools software or if trying to access the SD card like a jump drive so into menu and set USB modem to Memory from Fax
