Home | HP | Color LaserJet 2600n Printer | Print spooler unable to ...
HP Color LaserJet 2600n Printer
Problem for HP Color LaserJet 2600n Printer
Print spooler unable to connect tp printer,cable
By vinitshah on Nov 07, 2009
print spooler unable to connect to printer,cable being connected to VPN which blocks access to local network
Solution #1
posted on Nov 07, 2009
Not Rated)
manm
Rank: Wiz
Rating: 71%, 7 votes
Print internal configuration page and check for IP address in printed sheet and try to compare with the driver information
Check for LED at network card if it’s on
Try to send ping command to IP address to verify connection and if reply is confirm
Uninstall driver and reload and try to search the printer with IP or hardware address while loading driver
If still any problem it could be network card have problem need to be replaced
Was this helpful?
Yes
No
Popular Solutions for HP Color LaserJet 2600n
Questions and Unsolved Problems for HP Color LaserJet 2600n
Do you recommend HP Color LaserJet 2600n Printer?
Answer
Answer
magenta very pale. I have put a new cartridge in.
Answer
When I print a page with color across the entire width of the page, the colors on the left hand side... (More)
Answer
My 2600N HP color laserjet, The colors are not lined up, Printer needs to be manually calibrated.... (More)
Answer
there are 3 diagonal indentation stripes in paper
Answer
Change print status from Offline to online on HP 2660
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For HP Color LaserJet 2600n...:
Top Printer Experts
Rank: Guru Guru
Solutions: 689
Experience: 30 Years of professional repair and design.
Ask Me
Find more Printer Experts
Top Printer Repair
(800) 836-9287
Celebrating 14 Years Of Outstanding Printer Repair...
Laser Repair 911
(972) 907-9771
Printronix, IBM, Tally, Genicom, TallyGenicom,...
Sinca Printers, Parts & Repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
