Question about Mitsubishi WD-62525 62" Rear Projection HDTV
WD-62525 horizontal lines in picture when using component inputs
My WD-62525 works perfectly when viewing HDMI inputs but when I use the component inputs there are horizontal lines moving over the picture. I opened up the TV and found a number of puffy 1000 uF capacitors which I have replaced but the problem remains. Has anyone seen a problem like this and know how to fix it?BTW, the self diagnostic code is 12 (Ok).
  • Anonymous Nov 22, 2008
    I am using a cable card and everything is fine. Composite jack on the front is good. Only component inputs have an issue. Changed sources and cables. Is there a board that controls the component video inputs that can be changed? I thought about buying a PS3 and hooking it up HDMI to circumvent the problem if I am going to have to spend any money on the TV anyway.
    Any easy fixes please let me know.
    Doug
  • Mitsubishi Master
  • 8,617 Answers
Code 12 means the set isnt experiencing any shutdown symptons. I would check for more capacitors in the same circuit where you found the other often they show no visible sign of deterioration. If you need a service manual to figure out which capacitors are in that same circuit you can get the manbual for your set for 10.99 at the following link. They will even email it to you if you go back to the site and let them know you want it emailed. heres the link hope it helps.
http://servicemanuals.vstore.ca/
Posted on Jan 20, 2008
SOURCE:
I have a wd-62525 dlp i have pic and sound through ant. and hdmi but on component and video inputs i only get sound no pic
Hello
It seems to be some fault with its HDMI cable you connect to this device from the source. As you get sound by HDMI, and no picture at all, this indicates the fault with cable itself. There is a cution notice says that " To assure continued FCC compliance, the user must use a shielded video interface cable
with bonded ferrite cores at both ends, when using the PC or HDMI input."
Cheang the cable and check.
Oct 10, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Scrolling diagonal lines
The cable box signal on the components video have a too high refresh rate frequency, that is the reason for the lines.
Use RCA cables or an alternative connection.
Other solution is changing the display out settings for cable box (from PAL to NTSC etc.)
Sep 01, 2008 | Mitsubishi WD-62525 62" Rear Projection...
I have a Mitsubishi WD-62525. In general the picture is great from all sources (cable, component, and hdmi). However, there occasionally are very thin, horizontal lines that flicker across the screen....
I have seen this problem before. It is usually caused by a malfunctioning color wheel. Replacing it should resolve the problem. Let me know if you wish to fix it yourself so that I can find you a replacement.
Jan 16, 2011 | Mitsubishi WD-62525 62" Rear Projection...
I have horizontal lines on my Mitsubishi 62525 dlp tv. it does this on cable and component sources (only ones i have hooked up). When you pull up the tv menu these lines do not appear and also the lines...
Bad capacitors. On my set HDMI looks clear, but component inputs have moving horizontal lines. There's a guy named Tbully on AVS forum that did a PowerPoint presentation that will point you to the capacitors to change. Sorry I don't have a link at this time.
Oct 07, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-62525 BLUE SCREEN NO PICTURE NO SOUND
I had the same problem and I found that it was 2 caps on the power supply board. I had both caps replaced and it worked perfect. While it is apart see if any other caps are bad( if they are puffed up in the center they are bad).
Jun 29, 2009 | Mitsubishi WD-62525 62" Rear Projection...
I have a Mitsubishi WD-62525, and when the Directv installer came out, he said that he could not connect the box to my tv because he didn't know how to get my tv in HDMI mode. From what I am reading, it...
Your right connect the HDMI output from the directv receiver to an HDMI input on your tv. Change the tv input to the HDMI input and it should work. If your tv does not have HDMI input then it should have component input indentified as red blue green connectors on the back of tv. This is for video only. Connect the red and white for audio using the yellow/red/white cable that was included with receiver. The red blue green cable is also included with receiver as well as the HDMI cable. Did this installer educate you on how to use your directv equipment. If you are paying for HD access but your receiver is not connected the an HD input on your tv then you are not getting what you are paying for. This should of been resolved during the installation. The installer either is incompentant or just did not care. Call directv and demand them to make their receiver work with your tv if this means a field supervisor tech being sent out to correct this.
Mar 11, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Connection of HDMI and Directv box
Monlink is the Connection I used with my Directv. All you need to use is the HDMI cords. Are you trying to also connect to stereo system or something other than a straight HDMI connection from Directv Box to WD-62525
Feb 02, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Wavy diagonal lines only with component cables, not hdmi
You have a bad format board which is no longer available. the DM chassis can be sent in for repair by an authorized Mitsubishi servicer Call mit at 1 800 332-2119 they might help with cost of repair have receipt and purchase date available.
Jan 12, 2009 | Mitsubishi WD-62725 62" Rear Projection...
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
371 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
