Question about Sony NWZ-A816 Digital Media Player
Sony NWZ-A816 won't charge
I have a Sony Walkman NWZ-A816. Out of the box it charged and I was able to fill it with music. While using it it crashed and would not reset. I ran the battery down and now it won't charge. I can't get any USB to even recognize the it when it's plugged into the port. Please help.
  • 17 more comments
  • Tamalix Jan 16, 2008
    We just got a brand-new Sony MP3 Player NWZ-A816 in black. Upon plugging it in into the USB ports (and we have tried all three), the computer doesn't even see the player. It doesn't charge, it doesn't open as a peripheral drive. We went back to the store and they tested it there, works fine. Works fine with our neighbor's computer. At the end of the tether. Reinstalled SP2 (we have XP Home Edition, by the way), tried to look for the way to update the USB drivers, unsuccessful, so far. My Blue Tooth adapter and jump-drive work just fine. Any help is appreciated.
  • Lilytom Feb 13, 2008
    I have the same problem. First connected the walkman to my PC, it saw it fine as a new driver WALKMAN. I then installed Windows XP SP2 so MediaManager would work and since then it won't recognise it on any USB port. Tried rebooting, resetting, etc. Like the other person, works OK on my husband's PC but not on the PC where all my songs are!
  • Anonymous Mar 08, 2008
    I have a Sony Walkman NWZ-A816. I ran the battery down and now it won't charge. When my USB is in it only askes to import or export music, when I leave it plugged in it says Wvery momoent has it's music, all the buttons are frozen on it and it won't charge. Please help.
  • gameplayer May 20, 2008
    I connect the Sony Walkman NWZ ... to my computer and it just shows the message LOW BATTERY, please charge. yet it is supposed to charge when connected with the USB cable!
  • EugeneF Jul 19, 2008
    After my virus software was updated my sony walkman (NEZ-S616F) doesn't charge through the USB and songs don't appear on media player
  • Anonymous Aug 02, 2008
    won't charge
  • Anonymous Aug 11, 2008
    it wont charge when plugged in to the computer
  • CHONHUNT Aug 11, 2008
    I HAVE A NWZ-A816 AND MY MP3 HAD THE SAME PROBLEM HOW DO I FIX THIS OR RESET IT?
    hi, where I can get the charger for Sony Walkman A816.
  • Anonymous Aug 13, 2008
    I have the same problem. I try to reset while operating and it shut down. I try to recharge but the pc didn't even recognize it. How do I fix it?
  • kksundar Aug 22, 2008
    My Home computer will not recognize Sony NWZ-A816 when connected to any USB port. But the office computer does recognize. How could I make the home computer recognize the player?
  • Tommyplatt88 Sep 08, 2008
    Kay so i can plug in the USB and itll say charging and turn on... but when i unplug the cord nothing happens... wont even turn on... when i plug it back in i have to push the Reset button to get it to say charging again
  • Anonymous Nov 10, 2008
    nwz a816 sent me msg that battery was low.....i put it on the usb connection to the computer but still no response after two hours???
  • rlnan Nov 20, 2008
    My sony walkman nwz-a816 is not recognized by the computerand won't charge. all this hppened after reinstalling my virus protection.
  • Anonymous Jan 18, 2009
    Got a nwz-a816 and it connects to an XP SP2 system via USB. Display is showing "connecting USB (MTP". But when I opne explorer the "storage media" under "WALKMAN" is completely empty. It worked before I installed the Sony Ericson PC Suite. Annyone with the same issue?
  • Anonymous Jan 23, 2009
    I have a sony NWZ-A816 and it wo't charge
  • mcmenace Feb 04, 2009
    Player charged at first(via usb) but now nothing happens at all when plugged in...considered buying wall adapter?
  • smokey mcT Mar 23, 2009
    I am so pissed off. My walkman worked fine for about 8 months until sudenly out of the blue it was no longer recognized by the PC. It won't charge either. If I plug it in and I am stuck on the start screen where it prompts me to charge it, but it won't charge!!! So I am stuck with a good looking piece of plastic that SELF DESTRUCTED for no aparent reason. There seems to be no solution... I have tried all those that do not entail dissassembling it. I'm getting an ipod or something..
  • kwmsdl Apr 05, 2009
    I had the same problem, and it's clear it's a Windows Vista problem, not a Sony NWZ-A816 problem (at least in my case it is clear: I have two of them, and the both stopped charging or being recognized by my computer after a series of Vista updates).
    The post called "best solution" worked like a charm for me, although in Vista the term is "disable" and not "delete." Anyway, bith work prefectly now, thanks "recordnow" for posting the solution!
I had the same problem my mp3 would not charge.To fix connect the mp3 to your computer with the usb cable, go to Device manger open up portable devices you should see a small yellow triangle (this is telling you some thing is wrong) right click over walkman and choose up date driver .windows will use hardware wizard on the net to fix the driver.This worked for me i hope it fixes your problem
Posted on Oct 30, 2008
My computer did not recognize the player even after resetting. Here is what worked in my XP machine. Connected the player to the computer. Start - control panel - system - hardware - device manager - Universal serial bus contollers. The Walkman appeared with a yellow symbol. Right click on it and click delete. Take the player out. Reboot. Connect the player. Hopefully this will work for you.
Posted on Oct 31, 2008
I had the same problem. Battery ran down, screen frozen. I reset it using a pin. The reset button is located on the lower right hand side next to the metal loop used for a strap. reset is engraved right next to it. Once I did that it rebooted and works fine.
Posted on May 13, 2008
Just found this website so glad i did having prob. w/ nwz-a816 black screen looked dead to me computer wouldn't even recognize it used a paperclip to reset it and it fixed all the probs. why it did this i don't know but it's workin' now and i just wanted to say thank-you!
Posted on Jul 24, 2008
  • 4 Answers
I went through this for the last six months, and I have xp and vista. In xp, it would work, drag and drop, but on vista, I kept getting the mtp device error code 10. I finally chose the usb option it gives under the update drivers, then choose choose drivers yourself, then choice will be USB mass storage I think I chose, then suddenly, my CONNECT came on! I am soooo happy, now after four months I can add songs!!!!
Posted on Feb 25, 2009
Device manager/update driver/ c:windows/system32/drivers works.
Posted on Aug 26, 2008
Start, control panel, (on category view on Windows XP open performance and maintenance next then...), Administrative tools, Computer management, Device manager (under system tools), right click WALKMAN (with the yellow triangle beside it) and select update driver. continue with the instructions. this completely worked for me :) GOOD LUCK :D
Posted on Aug 06, 2009
Wow thnx ppl just reset it and it works.... i was just scared it mite delete data but everything is there!
Posted on Aug 24, 2008
Whenever I would hook mine up via USB wall charger or a PC, it would just tell me LOW BATTERY please charge.
I figured it was a bad battery, but I had it connected to my PC right now and hit reset a bunch of times (It hadn't worked before) and suddenly it's starting to charge.
So if you've run out of patience try hitting your reset button a ton of times while mashing other buttons, it actually worked for me....
Posted on Dec 14, 2009
For all the new people reading this, its an easy fix. Get an old tooth brush and dip it in some white spirit, then thuroughly clean the connections between the MP3 player and USB cable.
Hey presto, fixed.
Thank you and good night.
Posted on Jul 29, 2009
I'm considering this player but after seeing how many people can't charge it it seems iffy to me. I still don't have it yet but I have an on the wall charger USB to the wall then just plug the usb cable to the player. if someone has that would u mind trying to do that and reply to see if that works? cuz thats how I charge my old ones that i broke, oh another question is even if it doesnt charge can it still transfer music? from pc to the player?
Posted on Mar 29, 2008
Its a computer problem because i tried on another one and it worked.
To fix the one that didn't i used solution # 10 and BANG its fixed.
Thanks for your help
Posted on Apr 29, 2009
I have nws-s615f and was having the same problem not getting detected in usb
then i showed to sony showroon they said i have to replace its pcb as some problem and it will
cost some 4000 rs so i thought to buy better the new one.
And now as the battery was dead without charging and now this was of now use so i opened
it and just i brought parallel wire from battery and charged from my nokia mobile charger and within
10mins it get charged and now i am using as it was earlier but i can't load anything on it .
any way better then getting waste .
if u have tried all the method then ask me may be i could solve it ..p_rajmane@yahoo.com
Posted on Oct 15, 2008
Use the reset button. its on the bottom right. you gotta use a pin or something to push it. should work fine.
Posted on Jun 03, 2008
    Problem Solver:
  • 7 Answers
Not a solution for you but a solution for me, soldier currently in iraq and i have a NWZ-A816 and i love it, has 681 songs and all the pictures of my wife and family problem is i lost the usb cable on a mission last night so i am unable to charge it so if there is anyone out there willing to sell theirs (not to expensive wife is staying at home to take care of things so were living off my income) send me a email @ prerunnerrngr@yahoo.com
Posted on Jun 09, 2008
Walkman not detected /won't charge
I had a similar problem that was caused by the casing becoming loose on the back of the Walkman which prevents the power cable from connecting properly. Tightening the screws on the back fixes this.
Posted on Aug 16, 2011
  • darkhippie1 Aug 16, 2011
    Won't charge/connect to computer
    I had the same problem because the casing at the back became lose and the power cable wouldn't connect properly -its not immediately obvious. Tightening the screws on the back fixed that problem
Sony walkman nwz-s618f with the same issue: SOLVED!
Plug the power/USB cable on your computer (or on a iPhone usb power adapter) and press/hold [play/pause] [home/back] [pwr off/option] buttons until the "os" finishes to load (progression bar). That's it. I hope it will work for you too.
Posted on Aug 25, 2010
My problem is that it doesn't seem to charge... it says it's connected, the image on the player is normal, I can access my files, but when I unplug it, the thing won't stay on, it turns off after a few seconds every time.
I'll try a wall charger later and see. Thank you everyone.
Posted on Jan 13, 2010
  • jackoclovers Mar 30, 2014
    That seemed to have worked, after 4 years it's still working great!
идете на хуй!суки!
Posted on Oct 08, 2008
This player has been nothing but trouble, i have the nwz-a816 and it will only recharge if i hit reset. Now since it only shows up on any computer as an uknown device that is in-accessible, i think its safe to say i threw one hundred dollars out the window.... Junk, Lightweight, attractive looking-junk.
Posted on Oct 07, 2008
Hi, a wall charger (available at electronic stores) with the USB cable supplied with the walkman works well when you cannot charge it from the laptop.
I have a sony mp3 player NWZ-S615F. It is doing the same thing. It worked for about a month. Then I couldn't add songs. It would take a while for me to get it to charge the battery. Now it won't recognize it at all. I can't charge it. I have tried several times to reload the disc and have tried several ports on my computer to no avail.
Posted on Mar 15, 2008
My Sony NWZ-S639F fails to turn on. I pressed reset and it told me battery low and to recharge. I plugged in and the initial display came up . The blue line at the bottom of the display got three quarters of the way across the bottom and stopped and goes no further. Nothing happens from there. Reset and it does the same. HELP!!! Love the player but PLEASE COME BACK TO ME!!!!
Posted on Jan 20, 2010
  • fred1980 Aug 25, 2010
My sony walkman will not charge. I have a digital media player NWZ-A816
I'm sorry that the Network Player is not charging. Please click hear to view the troubleshooting steps for charging issue with the Walkman Player. Please let me know if you require any further assistance.
Thanks for understanding.
Apr 18, 2011 | Sony Audio Players & Recorders
Will my songs go away when i rest my Sony Walkman
Yes this reset button is a complete reset.
Hope it helps if so let me know>>>>>>fireabite@aol.com
Jan 05, 2010 | Sony Walkman Video NWZ-A816 Digital Media...
My sony walkman nwz mp3 doesnt want to charge or connect to my computer what should i do?
i had the same problem but now i know what to do : step1 dont connect it to the compuuter : step 2 connect it to a wire and then it will start saying connecting then it will be okay
Sep 01, 2009 | Sony Walkman Video NWZ-A816 Digital Media...
Sony walkman nwz a816 froze.
you can try formatting it and if that doesn't work try replacing the battery.if you don't know how to format email me at gamecrazy944@yahoo.com.i would try to format it first.(you will lose all of your songs but i will tell you a way to get free music fast and easy
Jun 29, 2009 | Sony Walkman Video NWZ-A816 Digital Media...
Nwz-a816 sony walkman how do i put videos on it
http://www.youtube.com/watch?v=cI41SLayVfg thats your answer
Jun 05, 2009 | Sony Walkman NWZ-S616F MP3 Player
How do I find out how to download and delete songs on my Sony Walkman NWZ-A816?
just use limewire to get songs u want then you can use windows media player to delete or put songs
May 13, 2009 | Sony Walkman Video NWZ-A816 Digital Media...
Sony walkman nwz-a816 getting usb device not recognized
okay, try plugging it in. Go to Startmenu, right click 'My computer', and select properties. Go to the 'Hardware' tab, then Device manager. Down at the bottom, you should see a section of the tree that can be expanded, entitled 'Universal Serial Bus Controllers' Find the Unknown device part. Select that, then go to 'Action','Uninstall'. After un-installation, the computer might restart. Unplug your walkman. When windows is back up, plug it in, and see if that works. if not, I have an alternative solution
Dec 30, 2008 | Sony Walkman Video NWZ-A816 Digital Media...
Sony walkman nwz-s18f froze
I had this problem a few days ago and now my sony nwzs18f has different problems, the way i got it to charge back up was by using a usb charger that plugs into a socket rather than into your computer this should hopfully charge it back up and also it should unfreeze the screen.
hope this helps
Dec 29, 2008 | Sony Walkman Video NWZ-A816 Digital Media...
Sony NWZ-A816 Digital Media Player Logo
11,816 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
