No is the simple answer, it is as result of doing too many low temp washes, the bacteria is building up on the door seal.
You must do a high temp wash with powder, but no clothes, at least 5-6 times a year, it is called a maintenance wash, and all manufactures recommened you do this.
Clean the seal as best you can, you will not get all the marks of, as it is ingrained into the rubber.
Please rate my solution.
Thanks.
my washer keeps stopping at 27 min then i have to press start again and then it starts all over and...
(More)
my washer keeps stopping at 27 min then i have to press start again and then it starts all over and then stops again at 27 min
It will not drain after the rinse cycle so the spin cycle will not start. The pump is turning on,...
(More)
It will not drain after the rinse cycle so the spin cycle will not start. The pump is turning on, but no waters coming out.
mold build up around door gasket; My washer stinks, when looking at the door gasket I can see mold...
(More)
mold build up around door gasket; My washer stinks, when looking at the door gasket I can see mold build up. Can the door gasket be removed, cleaned and replaced?
