Question about Akai PT50DL24 Television
DCE demo, DCE on, and DCE off show on the screen and I can't get rid of them. Any ideas?
0 characters
1 Points
I have 2005 jvc HD-61Z456 screen TV.. Has on screen D.I.S.T Dynamic Gamma .How do I turn that off without remote
This is the DEMO that you are viewing. Using the front panel use directional keys to undo Demo (DEMO OFF)
Jun 04, 2014 | Projection Televisions
Toshiba big screen tv wont quit streeming menu options
A model number would assist me in helping but here is a possible reason/s:
If menu keeps popping up may be a defective menu button on the set.
If set is actually going thru a "Demo" mode showing all features that demo has been turned on and needs to be shut off---usually in most sets it is somewhere in the setup or options menu.
Mar 19, 2012 | Projection Televisions
I can not turn off auto demo
To stop auto demo, press the MENU button, and select auto demo by pressing the up/dpwn buttons, and turn it off by pressing the left/right buttons. Press the MENU button to finish.
Dec 12, 2010 | JVC AV-65WP55 65" Rear Projection...
I can NOT stop the "verbiage" from appearing and
Your description sounds like your unit is in the "DEMO" mode. The procedure to access the demo mode and turn it on or off is in the operaitons manual. If you do not have one you can download one for free at . If you do not care about getting the maual and just want the verbiage to end here is the procedure:
To start the demo mode:
Press and hold the MENU button on the front of the set for 4 seconds.
To stop the demo mode:
Press RECALL, EXIT or Power
Thanks for using FixYa and for the great rating. Great ratings keep experts answering questions. Thank you.
Nov 17, 2010 | Toshiba 42H81 42" Rear Projection...
Can't turn off PIP on Sony XBR videoscope TV
Hit the set up button on the TV.
You'll see options to change the language. The last option is to put the TV in "Demo Mode."
Put the TV in Demo mode, when the first screen appears, "Welcome to...." the PIP will disappear.
Hit exit before the screen moves to the "Menu." If you miss it, watch the demo once--it will restart--and hit the exit button the next time you see the "Welcome to" message.
I just did this and it worked for me - i hope it works for you.
Apr 14, 2009 | Projection Televisions
Mitsubishi wd52525 problems
i have thought about this since you first posted it. if the demo is good then the light engine is ok. it sounds like a problem in the chassis. probably on the DM and the terminal board. to repair the chassis would cost about $250.00 plus shipping.
go to
Oct 19, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Magnavox television stuck in demo mode
My wife somehow put our Magnavox TV into demo mode too...
Plug in the set. With the set ON. Press the volume up (+) AND volume down (-) at the same time.
This worked to get it out of demo mode!
Jan 03, 2008 | Projection Televisions
A Big Problem
If you're talking about "demo mode", this is from the manual:
Demo Mode
This TV has a demo mode for use in retail stores. To turn the demo mode On/Off, press the following buttons in sequence:
MENU, 0, QV, 0
Hope it helps.
Oct 26, 2007 | Mitsubishi WD-52628 52" Projection HDTV
TP50H50 Black Box on screen
you may have the set in text mode (part of the closed caption menu)
Feb 07, 2007 | Toshiba TP50H50 50" Rear Projection...
Akai PT50DL24 Television Logo
Top Akai Projection Televisions Experts
Jaime Hernandez
matt martin
matt martin
Are you an Akai Projection Television Expert? Answer questions, earn points and help others
