Question about Hoover F6212-900 / F6215-900 SteamVac Agility Upright Vacuum
Hoover agility can a belt be replaced for brushes not spinning????? f6215-900
  • 1,673 Answers
I don't believe there is a belt, check the brush block and make sure that the shaft isn't broken off, if ok, then the turbine is bad and will have to be replaced.
Posted on Jan 06, 2008
Hoover windtunnel U5453-900.belt melted put another belt on brush was spinning.Brush spins but not easily.It spins then stops therefore burns the belt.How can i get the brush to spin around better
I would suggest taking the brush bearings at each end off and clean any lint or hair that might be in the ends of the brush. If you have regular ball bearings on your brush, you might need to replace the brush roller if the bearings themselves are tight. Hope this helps!
Apr 05, 2015 | Hoover Vacuums
Hoover Windtunnel model U6485200B troubleshooting brush not spinning
Hi! The brush-roll feature needs to be engaged for the belt to tighten, so when checking the belt it will appear to be loose. Be sure you have replaced both belts on the vacuum with genuine Hoover parts. This unit takes belt 38528034 and 38528035. Also, make sure the vacuum is on carpet mode. Follow the link to view the instruction manual which provides instructions and illustrations on changing the belt to be sure it is assembled properly.
Hope this helps!
Aug 08, 2014 | Hoover Vacuums
Hoover carpet cleaner brushes do not move
did you check to see if the belt came off or its stretched?
Jan 24, 2010 | Hoover F6212-900 / F6215-900 SteamVac...
Where is the belt on a hoover agility?? My brushes stopped spinning and I think that the belt broke but I cannot find it
If you have the manual it should show the location of the screws or clips that hold the cover on for the belt.
Dec 03, 2009 | Hoover F6212-900 / F6215-900 SteamVac...
Is my 6215-900 brushes drive driven by a belt? I
No, there isn't a drive belt on the Hoover Steam Vac models.
Oct 24, 2009 | Hoover F6212-900 / F6215-900 SteamVac...
Hoover Agility F6215-900 brushes won't spin
first it has to be on carpet mode. the vibration of the motor could have shook a wire lose or the motor is either jammed of has fried.
Jul 31, 2009 | Vacuums
Brushes don't spin
Remove the bottom cover and replace the broken drive belt. Check that the brush will rotate freely--likely everything is jammed with hair and dust. The brush assembly should just lift out of the case and the end bearings will pull off. The brush needs to be removed to install a new belt anyway. There should be a diagram that shows how to install the belt (it has a half-turn twist).
Jul 15, 2009 | Hoover F6212-900 / F6215-900 SteamVac...
There is no belt, sounds like the turbine is bad and will have to replaced.
Nov 27, 2006 | Hoover F6212-900 / F6215-900 SteamVac...
Hoover F6212-900 / F6215-900 SteamVac Agility Upright Vacuum Logo
172 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
