Question about Epson Stylus CX7800 All-In-One InkJet Printer
Windows VISTA compatibility
How can i get this printer to talk to WINDOWS VISTA.
  • Anonymous Feb 06, 2008
    How can I get my new BenQ CM3200 Series printer to communicate with my Windows Vista? I've already installed the printer driver, but I am undable to do any printing or scanning. Please help!
    Marius A Carelse
    South Africa
Please send me a driver for epson fx2175 window vista edwin_gulinao@yahoo.com
Posted on Jul 19, 2008
    Scholar:
  • 95 Answers
Posted on Jan 19, 2008
3 Suggested Answers
Tirzo
  • 94 Answers
SOURCE: epson printer and windows vista wont talk to each other
Windows Vista should automatically detect and install devices attached to the computer. Simply connect the printer to your computer and power it on.
If the driver does not automatically install, you can follow the steps below to install a resident driver which is part of Windows Vista. The resident driver installation should only be used if the printer is not detected and installed.
1. Click on START, CONTROL PANEL and PRINTERS.
2. Click the ADD PRINTER button. If you do not see ADD PRINTER, right-click in the PRINTERS window and select ADD PRINTER from the menu.
3. The ADD PRINTER wizard window will appear select Add a Local Printer.
4. Select the port the printer is connected to from the drop down window beside Use an Existing Port, click NEXT.
5. In the next window select EPSON under Manufacturers and your printer model under Printers.
6. In the Type a Printer Name window, Set as Default is automatically selected. If you, have another printer that will be the default simply remove the check and click NEXT to install the driver.
7. Ensure the printer is directly connected to the computer and that the printer is ready to print. Click PRINT TEST PAGE to test the printer.
8. Once the test page has printed, click FINISH to exit the wizard.
*NOTE:
-Depending on your system the computer may ask for your Windows disk, if so insert your Windows CD into your CD-ROM drive and click OK.
-As the driver is part of Windows Vista, there is no Status Monitor available for your printer. Some printers may have an INK LEVELS options included as part of the resident driver. Otherwise, the printer does have its own indicators. The RED error light will flash when the printer is low on ink and go solid when it is out.
-If the ink levels do not appear, click GET INK LEVELS from the MAIN tab of the printer driver. Ensure the printer is directly connected to the computer as the Ink Levels does rely on full bidirectional communication.
Posted on Jun 12, 2008
gwbm
  • 353 Answers
SOURCE: epson c60 printer not compatable with windows vista need a driver but have no idea where to download it
The driver for the Epson C60 printer is included with Vista - all you need to do is connect the printer to the computer with Vista running and turn it on. If you have already done this and the printer does not work properly (but see the info about the Status Monitor below), turn the printer off, uninstall the printer using the Control Panel-Programs and Features-Epson Printer Software, then reboot the computer. Once Vista is running, turn the printer on and it should then install OK.
HOWEVER, the printer Status Monitor (SM) is not included in this process and if you try to install the XP version of the SM, it will not work. Epson appears to have no intention of remedying this problem. This means you have no means of monitoring your ink levels, nor of changing the cartridges, cleaning the heads etc via the computer, although some of these tasks can be carried out via the printer control panel (see your hand book on how to do this).
A good solution is to use the free SSC utility as your SM - download from:
http://www.ssclg.com/epsone.shtml
Install it, and double click the ssc printer icon in the bottom right corner (System Tray). Choose Configuration and set your printer type (C60), then close the ssc window. Now right click the ssc icon in the sytem tray and choose the SM function you wish to use.
If you have any further queries on this, please post a new comment.
Posted on Mar 12, 2009
Epson Stylus CX4500 scanner not compatible for windows 7 how to solve this problem
hi.. i checked the epson website, and fortunately, i found a driver for your windows 7,
click this link
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&oid=25301&prodoid=36478881&infoType=Downloads&platform=Windows
and download :
TWAIN Driver and EPSON Scan Utility v3.04A
Windows 7 32-bit Edition compatible, Windows 7 64-bit Edition compatible, Windows Vista 32-bit Edition, Windows Vista 64-bit Edition
epson12258.exe
this is compatible for your printer, goodluck
Feb 17, 2010 | Epson Stylus CX5400 All-In-One InkJet...
Have new computer gateway with windows vista says windows connot find driveon the disk the printer is lexmark x1185
vista , till now does not have all the drivers for all the additional accessories....
for only a few devices and models in printers or cameras are available
Apr 11, 2008 | Office Equipment & Supplies
Running Vista and printer will not talk to cpu, I downloaded drivers and reinstalled all 3210 software please help!
chek ur printer driver whether it is compatible with windows vista or not go to hp website and download the proper driver update for vista.
Sep 07, 2009 | HP Photosmart 3210 Printer
Hello, I just bought a new laptop that has Windows Vista. My printer is a Hp Deskjet 5440 and it is not working. I dont think it is compatible with windows vista... is there a way to MAKE it compatible?......
HP Deskjet 5440 is compatible with 32Bit version of Windows Vista. You can check for device compatibility with Windows Vista at the link below:
http://www.microsoft.com/windows/compatibility/Default.aspx?type=Hardware
You need to install the drivers for this printer to make it work with Vista. To download the updated drivers for this printer, go to the link below:
http://h10025.www1.hp.com/ewfrf/wc/softwareDownloadIndex?softwareitem=dj-48092-1&lc=en&cc=us&dlc=en&product=445441&os=2093&lang=en
Aug 17, 2009 | HP Deskjet 5440 InkJet Photo Printer
Vista compatibility
no it is not because  compaq c3 1000 windows vista  is not good as windows 98 or the new windows 7
Apr 04, 2009 | Compaq C3 1000 3 In One All-In-One Thermal...
It seems not compatible
Please confirm are you using Windows Vista 32 bit or 64 bit
To determine product compatibility status , we looked at whether:
  • The product has earned the Certified for Windows Vista, Works with Windows Vista, or Games for Windows logo, which indicates that it has been tested for compatibility.
  • The device manufacturer or software publisher states Windows Vista support for the product.
Dec 30, 2008 | Brother Multi-Function Center MFC-3360c...
Do You Have Drivers for Windows vista. For these products x1100 & x63 tThey both work well,but I got a new Dell Computer with Windows Vista and need drivers compatable with it. Art...
Go to the following link and enter in the model of the printer, then select Vista for the operating system. I just installed vista drivers for an X1100 series printer last weekend. Worked GREAT!
http://downloads.lexmark.com/perl/downloads/downloads.cgi?ccs=229:1:0:0:0:0
Good Luck!
Dec 05, 2008 | Computers & Internet
Mp 160 printer drivers not compatible with window vista, I need compatible drivers for the same printer and window vista to download free.
This website has most drivers that you may need.
You can update your driver to work with windows Visa.
If not please let me know and I will get you what you need.
http://www.driveragent.com/ or click here
Jun 23, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Epson Stylus CX7800 All-In-One InkJet Printer Logo
77 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
