Question about LG WM1814CW Front Load Washer
Beko wma 1715s
I have a beko washing machine WMA1715S and its stuck on prewash and not move and hence not working. I tryied to switch it off and switch it on but its same again. The prewasch sign blinking all the time. thanks anz
  • 1 more comment
  • askgps Jan 09, 2008
    Thanks for that its okay now for the time being.
  • Anonymous May 21, 2008
    i have beko wma 1715 s i have a flshing light on prewash were it says prewash, main wash, conditioner, spin try holding start and wait to go on spin no luck can you help
  • robocop2222 Apr 07, 2009
    beko wma washing machine buttonkeeps flashing on conditioner so machine frozen and cant use it tried switching on and off and holding cancel button but still wont work any ideas how to clear it
The Child lock is in the on mode lol.....
Press and hold the two buttons quick wash and anti crease or
pre wash and extra rinse for 4-5 seconds ...Note the pre wash blinking light will go off and your machine will be ready to use again. the pre-wash blinking light indicates that the child lock has been activated......
Posted on Aug 20, 2008
  • Adrian Reid Sep 04, 2008
    is the top right pre - wash is blinking and stuck in child lock mode ?
    Hold the start button in and the anti crease at the same time turn the machine off and back on whilst keeping the buttons pressed in, then the top left pre-wash is blinking, then hold the quick wash and the anti crease buttons in for 4-5 seconds. the machine is outta child lock mode . Ready to use again !.
    I have wma 1715s and these sequences worked for me
I have the same fault and that solution will not work, it has happened to me about 3 times now, previously it would reset after about 20 times of trying but this time i can not get it to do anything, thanks anyway..
terry
Posted on May 26, 2008
Hi there,all you need to do is press the start button and hold it in till it goes on to spin/end this will cancel the previous cycle and allow you to put it on the cycle you want,
good luck,Ladydee78
Posted on Jan 05, 2008
Wme8227s. What does code E18 indicate?
Beko Washing Machine ' WMA Series ' Error Codes
www.ukwhitegoods.co.uk/.../fault-codes/...fault-codes/3623-beko-wma-...
Feb 6, 2013 - ... Fault Codes. Beko WMA Washing Machines With Display ... BekoWMA Series Washing Machine Fault Codes. These fault codes are ... E18 ...
UK Whitegoods • View topic - Beko WME7247W showing error code e18 ...
www.ukwhitegoods.co.uk/.../washing-machine.../beko-wme7247w-show...
Jun 19, 2011 - Hi, does anyone know what error code e18 is on a beko wme7247wwashing machine? thanks. User avatar louisebaxter: Whitegoods Newbie Beko wme7247w dc module burnt out
Apr 27, 2014
Bosch WAS24460GB showing error F:57
Sep 28, 2013
beko washer error code
Aug 18, 2012
Samsung B1415J showing error code EA ...
Jan 9, 2012
More results from www.ukwhitegoods.co.uk
Oct 30, 2015 | Beko Washing Machines
I need to buy the instruction booklet for the beko WMA 620 W washing machine.
This is the link where you can download user manual for BEKO-WMA 620 WASHING MACHINE
http://www.2instructions.com/results_mm.php?materiel=Washing%20Machine&marque=BEKO
hope this helps you,thank you
Feb 08, 2011 | Washing Machines
The prewash light won't stop flashing and washer
get it checked by and expert it sounds like the board has gone or the door lock is faulty
Jun 28, 2009 | Washing Machines
Beko WMA 510 stuck on cycle
Hi if your beko WMA 510 washing machine wont drain or has a spin problem then you have to check the carbon brushes first.
Also check all waste pipes are clear and inspect the pump I have included this video below.
At our website I am doing self diagnostic videos on these beko's as we speak so all tutorials will be in this link below
How to replace Beko Washing Machine Motor Carbon Brushes
you might find this test video helpful but only do it if you have checked the motor
Sep 05, 2008 | Indesit W 123 Front Load Washer
Beko WMA 1715s - won't respond
door lock switch could be your problem..
Aug 30, 2008 | Whirlpool LCR5232H Top Load Washer
I have a beko WMA 1715s washing machine, it will not work, the pre wash light is just flashing on and off, it will let you select a programme but when you press start it wont work, please can you help, i...
Either the child lock is on - press and hold quick-wash and anti-crease, at the same time for three seconds.
Or your machine need re-seting
Turn power button off (not at wall)
Select 90 degree wash
Press Start and Cancel button down at same time for 3 seconds and turn power button on whilst still holding buttons down - Start light will flash.
Leave power on.
Select any Spin position.
Press Start and Cancel button at same time again for 3 seconds - other buttons may start to flash - if they do, press Start and Cancel button together again for 3 seconds.
Machine should be re-set ready for use.
Apr 26, 2008 | Washing Machines
Beko wma 665 w all the leds displays are and nothing is happening
Just need to ask you that my Beko washine machine with model number wma 665 w is not taking water when you start it, before that it was stuck at 1min digital display screen rather than 30min, now showing 30mins but not taking water to start.Could you please help me to solve this problem?
Cheers!
Beko WMA 1715S
try unplugging and let it reset itself
Apr 03, 2008 | Washing Machines
LG WM1814CW Front Load Washer Logo
1,526 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
