My garage door just stops like the power was shut off. Within seconds to a minute the lights come back on. I can then press button and door will finish its cycle. Any thoughts on where to start?
I would pull the logic board and check for loose or missing traces on the printed circuit board. Especially around the small transformer. Electrical storms seem to love garage door openers.
I just replaced the drive gear which had gone bad. When I started it up, the door moves down about 6...
(More)
I just replaced the drive gear which had gone bad. When I started it up, the door moves down about 6 inches then immediately returns to the start position. The safety sensors are still in place and the light is not blinking. I have adjusted the downforce without benefit. By rapidly pushing the start button, I can force the door excursion to the floor eventually, but it is not really useable. Have I messed up the logic board in the process of replacing the drive gear?
door starts and stops. I have:
Adjusted down force controls still starts reverses then...
(More)
Adjusted down force controls still starts reverses then stops
checked door sensors OK
checked motor OK
Door will only go up or down if you unplug the unit and then plug it in, without anything else the...
(More)
Door will only go up or down if you unplug the unit and then plug it in, without anything else the door will go up or down depending where it is, then no more work until unplugged again
my 10hp 5600w generator only runs for approx 20 mins then stalls. fires back up on first...
(More)
my 10hp 5600w generator only runs for approx 20 mins then stalls. fires back up on first pull.sometimes almost completely stalls then kicks in
