Cuisinart DCC-2000
Water won't move from reservoir/showerhead to...
shared by 2 users
posted by LisaBurke on Jan 05, 2008
The water in our 14 cup Cusinart coffemaker heats up, but then seems to get stuck and does not pass through the "showerhead" and basket with the ground coffee. Then coffeepot beeps as though the pot is brewed after a minute or two, though there is nothing in the carafe.
We think it's clogged, but don't know how to get to the clog. Any ideas?
It's too expensive to throw away and we'd love to find a repair person in the area if we can't do it ourselves (Minneapolis).
(The product number is actually DCC-2200, which isn't on the list)
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Posted by cderekreed on Jul 26, 2008
I have the same problem and attempts to decalcify have failed!
Solution #1
posted on Jan 14, 2008
Not Rated (0)
coffeediva22
Rank:Master Master
Rating: 85%, 13 votes
You can try cleaning the unit first and if that doesn't work you can contact Cuisinart Warranty at 1-800-726-0190 and see what they can do for you. Do you have the original user manual that came with the machine?
As per my book on my unit (DCC-2000) you can try decalcifying the unit. I have never had any problems with that, but I use filtered water all the time and that may be the reason mine is working very well (except leak) after 18 months of age.
Per user manual....
Decalcification refers to removing the calcium deposits which form over time on the metal parts of the coffeemaker.
For best performance from your coffeemaker, decalcify the base unit from time to time. The frequency depends upon the hardness of the tap water and how often you use the coffeemaker.
To clean, fill the water reservoir to capacity with a mixture of 1/3 white vinegar and 2/3 water. Turn the coffeemaker on by turning the ON/OFF knob. One cycle should be sufficient to adequately clean the coffeemaker. When the cycle is completed and the five beeps sound, turn coffeemaker off. Repeat operation, this time using fresh cold water.
Good luck and I hope this helps your problem.
Coffeediva22
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Water won't move from reservoir/showerhead to carafe:
I don't want to Accept this solution
Can you Help with these Coffee and Espresso Makers problems?
Cuisinart DCC-2000
I bought a red Cuisinart 12 cup coffeemaker DCC 1100 this...
Cuisinart DCC-2000
The coffee leaks from ethe dispensor spout after it is...
Cuisinart DCC-2000
the clock on my coffee maker does not light up and is very...
Cuisinart DCC-2000
Nothing works. Won't brew. Clock is dead. No functions.
Cuisinart DCC-2000
Will not brew most of the time. Every so often it will go...
Loading problems.
Repair Service
Find Coffee and Esp. Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
