KitchenAid 24 in. KUDS02FRSS Stainless Steel Built-in Dishwasher
Problem for KitchenAid 24 in. KUDS02FRSS Stainless Steel Built-in...
Unit has power to it but will not turn on
By wwb357 on Nov 07, 2009
unit has power to it but will not turn on
Solution #1
posted on Nov 07, 2009
Not Rated)
jsrock516
Rank: Guru  KitchenAid Expert
Rating: 96%, 6849 votes
Yes, there is a thermal fuse (also known as a bi-metal) located behind the operator console. The part number for the replacement is W10258275. You can view an illustration at pcappliancerepair.com. It sells for about $15.
NOTE: The thermal fuse usually blows for a reason, but they can fail on their own too. If the fuse blows again following replacement, you may have a malfunction somewhere that you will need to isolate to determine the cause. There is usually a technical data sheet included with the appliance behind the lower toe panel under the door that inlcudes all troubleshooting information, diagnostics and wiring diagrams.
If you need to view a diagram of your dishwasher, enter your model number at the website mentioned for some excellent exploded view illustrations. The thermal fuse is listed as item 6 under the "Control Panel Parts" heading.
If you have any questions, please let me know. I hope this helps you.
Was this helpful?
Yes
No
Popular Solutions for KitchenAid 24 in. KUDS02FRSS
Questions and Unsolved Problems for KitchenAid 24 in. KUDS02FRSS
Do you recommend KitchenAid 24 in. KUDS02FRSS Stainless Steel Built-in Dishwasher?
Answer
Answer
my Kitchenaid KUDS02FRSS dishwasher will not start. The panel lights are on but it will not start... (More)
Answer
Water filling internal tub and overflowing on the floor while it is not operating.
Answer
the wash cycle light for both the normal wash and light china lights are flashing
Answer
the electronic panel lights up and all lights stay on . The lights are not on full strenth...just a... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For KitchenAid 24 in. KUDS02FRSS...:
Top Dishwasher Experts
Rank: Guru Guru
Solutions: 3922
Experience: 30 yrs exp home bldg, plumbing, wiring, framing, design & spring water usage. Problem solving.
Ask Me
Find more Dishwasher Experts
Top Dishwasher Repair
(423) 303-3783
Dishwasher parts delivered overnight nationwide....
 Appliance Parts Pros.com
(800) 803-6775
Manage my home, all the technicians you need at...
Manage my Home
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
