Question about Linksys Wireless-N WRT150N Router
Can't connect to the router
Maybe this is a simple solution. I have Windows XP.
What do I enter when it asked for the network key?
Shared Key? It does not appear to work. I was able to get connected once, but there was no IP address listed.
I changed the IP address manually as instructed in the support manual, but did not work.
I am able to connect with unsecured networks around me.
  • janedoe162 Jan 08, 2008
    Thanks for trying, but the problem was more basic.I had to call Linksys technical support to set the keys through the 192.168.1.1 site.
    My current problem is that I can't seem to keep the connection over a length of time...
    Scholar:
  • 47 Answers
Hi janedoe162,
Have you setup a key on the router? WPA-TKIP is the most secure but can be a little tricky to setup. Perhaps WEP-128 bit would be okay until you get use to the router. A lot of user guide reading required!
  1. Chose which type of encryption your going to use
  2. set a key on the router. Depending upon what type you chose the key can be either a pass phas, ASCII text, or hexadecimal numbers (HEX). Make it a difficult one so other can't guess what it is!
  3. Then save the setting on the router and reboot it. (tun it of and on again.
  4. Wait for a few minutes while it sets it's self up, need to make connections to the internet and your PC.
  5. Using a wireless adapter try to connect to the the router SSID, which should be the default if you haven't changed it.
  6. The router should prompt you for the key. This is the shared key you set on the router.
  7. Wait a few seconds while they shake hands! (geek joke) and you should now be connected to the your wi-fi access point.
Hope this has helped you.
Regards,
Spare head 2.
Posted on Jan 05, 2008
I have a windows xp and i would like to setup a WEP/WPA key
When youclick Refresh network list, then Choose yourwireless network and then click Connect to your secured WirelessNetwork, it will asks for a Network Key before allowing you to connectinto your wireless network. This Network Key is either the WEP, orWPA or WPA2 Encryption key that is used to configure the Wireless Router. The Passphraseis an alternate way to setup the Encryption key.
When you are requested for a Network Key, you can just enter the Passphrasethat was used to configure the Encryption key in the wireless router.http://www.fixya.com/support/r5270415-network_password_network_addressFor information on securing your wireless network,configuring the wireless router and configuring the wireless card in thelaptop/computer, please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Jan 04, 2012 | Microsoft Windows XP Home for PC
Tip
Windows problems connecting to WPS enabled routers
You may come across connection problems when routers have Wi-Fi Protected Setup (WPS) enabled and clients do not support it.
In Windows XP, Wireless Zero Configuration (WZC) may mistake a WPS enabled router for a WPA-Radius protected one and warn you that there is no certificate to connect to it:
To work around this problem, you can either disable 802.1x authentication on the client or disable WPS on the router's.
802.1x on the client can be disabled in the properties of the wireless network. On the Authentication tab, untick the 802.1x Authentication option. Make sure that the correct encryption type is selected on the Association tab and that the WPA Pre-Shared Key or the WEP key is entered.
On Windows Vista things may even be worse. When you try to connect to a WPS enabled network, Vista may prompt you for a user name, password and domain name as if PEAP authentication were used. When you manually create the network profile specifying WPA2-PSK, AES and the Pre-shared Key, Vista may refuse to connect stating that the network profile does not match the actual configuration. The only work-around in this case is to disable WPS on the router.
To disable WPS on the router, go to the Wi-Fi Protected Setup.
To learn how to disable WPS click here...
At the top of the page, just set WPS to disabled and apply changes. You may need to delete the profile for the network on the client card before it can connect to the router.
on May 05, 2010 | Computers & Internet
Hot to secure my router from my neighbors using them. thanks
click this link to open the router login http://192.168.1.1/
When asked for username use admin and password leave it empty
then goto
SETUP -> WIRELESS SETUP -> MANUAL WIRELESS CONNECTION SETUP -> WIRELESS SECURITY MODE and select "Enable WPA > WPA -> WPA Key -> create your own password and save now if you want to access the Wireless connection you will have to enter the WPA key you just created.
Apr 11, 2011 | D-Link DIR-600 Router
Acer aspire one d255 hi,ihave new aspire bun not connected in network
Hi Friend,
While connecting to your network if it asks for a network key and if you are not aware of that, please follow the steps:
Type 192.168.1.1 in the web browser and hit enter. If you have not changed the router password then kindly enter admin as the password and leave the username blank and hit enter.
In the router setup page click Wireless and click Wireless Security. Whatever the security mode is selected you will get the shared key over there which you can use while connecting your laptop.
Regards
Chiranjeet
Sep 22, 2010 | Computers & Internet
Broadband wireless adapter limited connectivity issues
If the wireless security on the router is enabled, then the pre-shared key or encryption key on the router and PC should match.
To check the wireless settings, use the laptop to access the web interface of the router. Follow the steps below:
1 Using your Internet browser, go to http://dsldevice.lan or to the IP address of your router (by default: 192.168.1.254).
2 On the Home Network menu, click Wireless.
3 In the upper-right corner, click Details.
4 The wireless Access Point page appears. Under:
- Configuration, you can find the network name (SSID).
- Security, you can find the encryption.
On the PC wireless, access the wireless network connection. Select the SSID and then type the encryption key or pre-shared key.
Once the encryption key on the PC and router matches, then you should obtain an IP address and get online.
Nov 27, 2009 | Computers & Internet
Wireless connection for Win 7
If you are trying to connect to the wireless network, then first you should know all the wireless settings of the router ( SSID , Security key or password).
If you don't the wireless settings of the router , then you will need to access the router set up interface.
On the set up page of the router you will be able to find the wireless settings of the router.
Once you have the wireless settings of the router then you just need to connect to the wireless network on your computer.
For Windows XP -
In case of windows XP computer you will find the wireless network connection Icon In the bottom right hand corner. right click on it and go to the option " View available networks ". You will be able to see your wireless network. If you do not seethe icon there , then try START ==> Control panel==> network connection. You will find the wireless network connection option.right click and go to " View available networks ".
If you get the message " Windows can not configure this wireless network " , then there is another software utility on your computer which is managing your wireless network. You will need to use that utility to connect to the wireless network. Suppose you have Linksys adapter on your computer , then there must be Linksys utility on your computer which can connect you to the wireless network. if you are not able to connect using that utility then you can switch over to the Windows Utility.
If you get the message " NO wireless networks are found in the range " , Make sure that the wireless switch on your laptop is turned ON. On the laptops there might be a wireless Switch that you will need to turn on. On Some laptops the wireless switch may be the combination of Fn + F2 Or Fn + F5 Or may be different than that. Once you turn on the wireless switch you will be able to connect to the network.
If you seethe wireless network and you tried to connect to the wireless network , some times you will get the message " Waiting for the network to be ready ". That means you might have tried to connect to this network before with different wireless settings . In this case you will need to remove the network from the preferred networks and try to connect again.
WINDOWS VISTA/ Windows 7
In case of windows You will find 2 computer icon in the bottom right hand corner.Right click on it and go to the option " Network and Sharing center ". Once you open the network and sharing center you will find the option " connect to the network " in the top left hand side. Click On connect to the network and you will see the wireless network that you want to connect. If it secured network then type the network key or passphrase and you will be able to connect.
If you get the message " additional log on information required " then you will need to add the wireless network manually.
If you get the message " settings saved on this computer do not match ..." then you will need to remove the network from the preferred network list. Try to connect again.
If you get the message " Press the configuration button ..." , On the same window at the bottom you will find the option " I want to enter the key manually " or " I don't want to configure the network ..." Click On it and it will ask you for the key.
If you see " Enter PIN number " , then at the bottom you will find the option " I want to enter the key manually " or " I don't want to configure the network ..." Click On it and it will ask you for the key.
For MAC OS
In case of MAC OS, you will find the AIRPORT icon the right hand top corner. If you click On it, it will try to connect to the wireless network. If you network is secured then it will ask you for the wireless network key or password. type the key and it will connect you to the network.
If you get the message " error joining the network " and if the wireless security type is WEP, then try to connect to the wireless network again. It will ask you for the network key / password again. Now this time enter $ sign before entering the network key . It will connect you.
Click Here for more info
Nov 25, 2009 | NetGear DG834G Router
How do i hook up 2nd computer to router wireless ''g'' wgr614
Hi, if this computer is going to be wired then just connect it to the router using a ethernet cable and can access internet.
For wireless, follow the steps below to check security key:
Please follow the steps on a computer connected to the router so as to check the network key:
1. Open the browser(Internet Explorer or Mozilla Firefox).
2. Access the router usually http://192.168.1.1 else try http://www.routerlogin.com
3. Login to the router (User Name = admin Password = password unless you have changed it).
4. Click on Wireless Settings'(under Setup) from the left menu.
5. Check if 'WEP (Wired Equivalent Privacy)' or 'WPA-PSK (Wi-Fi Protected Access Pre-Shared Key)' is selected under 'Security Options'.
6. If WPA-PSK is selected, copy the code entered in the passphrase.
7. If WEP is selected, copy the code entered in the Key that has a black dot before it.
This is the code required for connecting the wireless computer to the routers' wireless network.
In some cases, for security reasons the passphrase might show as asterisks. In this case type a new password and click apply. You will then have to use the same password for all the wireless devices connecting to the network.
Scan for the wieless network on the concerned computer and connect to the network.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Jun 27, 2009 | NetGear WGR614 Wireless Router
Can't connect to my router anymore (WEP encrypted).
Hi deray953,
First we need to remove the previous profile in your wireless network. I believe you know the SSID for wireless connection using WEP security. You can check this by going to;
Using Windows XP SP2/3
1. "Control Panel" > Switch control panel to classic view ( look at the upper left side ). > Double click "Network Connections" > Right click "Wireless Network Connections" > choose "Properties"> Click the Tab "Wireless Networks" ( middle tab) > go to the list of profiles and remove the Wireless name or SSID for your home connections. > click OK and Close the properties of wireless.
To reconnect again, you need to know your WEP key or network key for wireless connections if not, you can do this procedure...
1.Connect the computer to one of the four LAN ports (i.e port 1, 2, 3 or 4) on the back of the router. The corresponding port light where you connected the computer should be lit up.
2. Access the router's web-based utility.
a. Please open any web browser like Internet Explorer or Netscape Navigator.
b. Connect to the router by typing http://routerlogin.com/basicsetting.htm or http://192.168.1.1 in the address field and click Enter or Return key.
c. A window will prompt for a user name and password. By default, the user name is "admin" and the password is "password".
d. Click on the Wireless Settings under Setup.
e. take note of the KEY 1 ...that is your WEP key..take note of it.
Connecting Through Wireless Zero Configuration (Windows XP SP1 and SP2)
For Windows XP Service Pack 1:
1. Please right click on the Wireless icon on the right lower end portion of your computer. Then, click on View Available Wireless Networks.
2. Click on the Advanced tab.
3. Please delete all the preferred networks then click on OK.
4. Right click on the Wireless icon again and click on View Available Wireless Networks.
5. Please select your network and click on Connect. If you have Wired Equivalent Privacy (WEP) or Wi-fi Protected Access (WPA) enabled on the router, it will ask you for the network key. Please type in the Network Key and then confirm it.
6. Make sure not to enable IEEE and then click on Connect.
For Windows XP Service Pack 2:
2. Click on the Change Advanced Settings.
3. Click on the Wireless Networks tab remove all the preferred networks then click on OK.
4. Right click on the Wireless icon then click on View Available Wireless Networks.
5. Select your network and click on Connect.
6. If you have Wired Equivalent Privacy (WEP) or Wi-Fi Protected Access (WPA) enabled on the router, it will ask you for the network key. Type in the network key and confirm it. Then click on Connect.
Note: You may use the wireless utility of your wireless adapter in connecting to the wireless network but you need to clear "Use Windows to configure my wireless networks" on the Wireless Networks tab.
Connecting to a Wireless Network on Windows Vista:
a. Click Start then select Connect To.
b. Connect to a network window will show up.
c. Select your wireless network's name or SSID and click Connect.
d. It will ask you for a network key. Type in your wireless network key on the field provided. Then, click on Connect.
Apr 02, 2009 | NetGear RangeMax WPN824 Router
Connect dlink to n95
Hello...the pre-shared key is also known as the network key, and you can find it within your router settings.
Open a web browser, and login to your router by typing http://192.168.0.1 into the address bar.
You are prompted for a username and password. Enter username: admin and leave the password blank, or enter your password if you have set one.
Go to Home >Wireless. You should see your pre-shared key, or network key there.
Hope this helps you, but please come back to Fixya if this does not work or you need further help.
Jan 17, 2009 | D-Link AirPlus DI-524 Wireless Router
Cannot connect to wifi from bt home hub any suggestions. laptop higrade 8615gtx
Could be a variety of reasons.
Assuming you have not had it working before
Assuming the wifi is broadcasting it SSID
Assuming you have laptop connected by ethernet cable to hub:
Assuming you have XP:
Go to start/control panel/network connections/right click the wireless lan icon and select properties/select wireless connections and delete ALL previous entries.
With Vista go:start globe then
Control Panel\Network and Sharing\Manage Wireless Networks and delete all entries
Now:
press windows key and R
type cmd and enter
type ipconfig and enter
note lower set of figures ie 192.168.0.1
open browser and type in those figures and enter
should now open router firmware
When asked for log in use defaults of admin - admin or admin - password
navigate to wireless security and set encryption to WEP 64bit and create a simple encryption code - save settings
Change broadcast channel to 8
make sure wifi is set to open and not shared
Save all settings, allow hub to reboot and now see what happens
Dec 10, 2008 | Computers & Internet
Linksys Wireless-N WRT150N Router Logo
32 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
