Question about Sharp R-320H Microwave Oven
Numbers 1,3, 4 and 6 no longer work
On the touchpad, 4 of the numbers no longer work no matter how hard or offset you press the numbers. I think it's the touch pad itself, not the electronics since everything else works fine. Just want to verify it is probably the touchpad and not some other possibility.
  • Sharp Master
  • 9,098 Answers
It's probably the keypad. The keypad is a thin plastic membrane type that is glued to the plastic control panel frame.
If none or only some of the pads are working, there may be some foreign substance on the circuit board, the keypad connection, or inside the layers of the keypad, the latter of which cannot be repaired.
Trouble is sometimes due to spray cleaner being sprayed directly onto the keypad. Cleaner should be sprayed on the cloth first, then use the cloth to wipe the keypad clean.
Never use an ammonia-based cleaner on plastic as the ammonia can attack and crack it.
A handy person can remove the control panel frame and see if there's any liquid inside on or behind the panel. If so, it is possible to dry it out, but often that does not work.
Another thing is to unlpug the power at the mains for several seconds. Plug it back in and see if it works. A reset may do it. At power-up, the display should flash or show a text
message. If not, a key may be stuck due to a foreign substance or a defective keypad.
We have critical safety, disassembly, and troubleshooting info at our site. You'll find a link to our site in our listing here on FixYa: http://tinyurl.com/yzjozk
If certain keys are not working, there may be some foreign substance at the point where the green or blue plastic strip from the keypad plugs into the circuit board. To check that:
1. Be sure the oven is disconnected from the power line while you are taking it apart.
2. The keypad connection is the green or blue translucent plastic strip that plugs into a connector near the edge of the board.
3. There are two tiny tabs (one on each side) of the connector that you can gently pull up on to unlock the connector.
4. Then the keypad strip will lift out. Clean both sides of the end of the strip with a pencil eraser or alcohol-based cleaner if you like, but do not use ammonia-based cleaner. Dry the end of the strip.
5. Put the keypad strip back in, making sure both sides are down fully.
6. While holding the strip down, push the connector back down to lock it.
7. Try the keys again with the door closed.
Also, you must have the door closed for the START button to work.
You can probably find an exploded view by entering your FULL model number here: http://www3.sears.com (the 3 is correct)
You can order Sharp parts from there or from Tritronics at http://www.wehaveparts.com
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Jan 13, 2008
My keypad went completely off. Using the above suggestion, I pulled the keypad so the back was slightly opened, placed an alcohol swab on the end of a screwdriver and brushed it lightly against the circuit board, and PRESTO, my keypad is working COMPLETELY now!!!
Posted on Jul 12, 2009
Only three buttons on the touchpad work,#1,7 and clock
try e spares for replacement pad e spares.com
Apr 20, 2015 | Microwave Ovens
Control panel touchpad does not work; push buttons for Vent, etc. are ok and clock is working. Sometimes when I press the Vent button, I get a message saying the charcoal filter needs replacing. I looked...
follow this steps and fix it. God bless you
  1. Controller is confusedA power surge or random non-reproducible action of the universe may have resulted in the controller's program ending up in an infinite loop. Pull the plug for a minute or two to reset it.
  2. Defective Interlock switchesThis can result in the controller thinking the door is open and ignoring you.
  3. CleaningCleaning solutions (spray cleaner) may have gotten inside and shorted out the touchpad or controller. If this happens remove the touchpad, let it air dry for a few days, and then attach it back on the microwave.
Read more: http://www.appliancepartspros.com/repair-help/microwave-repair-help.html#4#ixzz2hVdoScpK
Oct 12, 2013 | GE SpaceMaker Microwave Ovens
Je1540wv002
follow this steps and fix it use the VOM 4f0e2859-427b-40e9-9e89-e7e7bb5bc8da.gif. God bless you
1. Door is not closed (some models).
2. You waited to long (open and close door to wake it up).
3. Controller is confused (pull plug for a minute or two to reset).
4. Defective interlock switches.
5. Faulty controller or its power supply.
6. Touchpad or controller board contaminated by overenthusiastic cleaning.
7. Defective/damaged touchpad.
Jun 11, 2013 | GE JE1460 Microwave Oven
Buttons on microwave
testing every step and fix it. God bless you see the diagram attached
Microwave Buttons Don't Work
Touchpad and Control Panel
If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Touchpad
If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the dishwasher display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
User Control and Display Board
If the microwave buttons don't work the user control and display board are most likely defective and will need to be replaced. If some of the buttons work and some don't, it is more likely a touch pad problem and the touch pad will need to be replaced.
Main Control Board
If the microwave buttons don't work the main control board is most likely defective and will need to be replaced. If some of the buttons work the touch pad is likely the problem. If none of the buttons work the problem may be in the main control board.1_24_2013_5_23_47_pm.gif1_24_2013_5_24_54_pm.jpg
Jan 24, 2013 | Goldstar MV-1501 Microwave Oven
Samsung microwave oven model smh9207st shows 5e
Try heating up touchpad with blowdryer , if that doesnt work replace touchpad.... On the smh9207st remove plastic cover from the back of the door . Remove 4 screws and 1 screw at the top of the door . Unplug two connectors Gently. ... Peel off front touchpad . Install is reverse of removal . Be safe .....part was $45 @ repairclinic.com
Jan 21, 2012 | Samsung Microwave Ovens
I lost my instructions for my Pasta Boat and I don't know what power to use or how much water.
For elbow, bowtie, ziti, rotini, and penee
1 serving -1/2cup -water level at #1
2 servings -1 cup -water level at #1
3 servings - 1 1/2cups - water level 2
4 servings - 2 cups - water level at 4
6 servings - 3 cups - water level at 6
8 servings - 4 cups - water level at 8
cook times based on serving size ( serving size - minutes)
1 - 17
2 - 18
3 - 21
4 - 23
6 - 25
8 - 27
Stir macaroni once halfway through cooking for al dente; for softer pasta, cook several minutes longer.
and just because I couldn't find this online no matter how hard I tried:
For spaghetti, linguine, angel hair and fettuccini
1 serving - 1/2 the handle - water level 1
2 servings- 1 full handle - water level 2
3 servings- 1 1/2 handles - water level 3
4 servings- 2 full handles - water level 4
6 servings- 3 full handles - water level 6
8 servings- 4 full handles - water level 8
cook time servings/minutes
spaghetti - 1/13-14, 2/15-16, 3/16-18, 4/18-20, 6/20-22, 8/22
thin pasta-1/12-13, 2/13-14, 3/15-16, 4/17-18, 6/19-20, 8/21
angel hair- 1/11-12, 2/12-13, 3/13-14, 4/14-15, 6/15-16, 8/17
Jan 10, 2011 | Microwave Ovens
Kenmore Microwave Oven Model#721.66463 built-in Button #2 does not work - when pressed, it says "3". #1 and #3 work fine. Crazy! I turned off the breaker, tried to reset the clock, but when it comes...
It appears your touchpad/controller has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Oct 27, 2009 | Kenmore 64683 Microwave Oven
Sharp Microwave Oven Timer Counts Down Very Fast (Demo mode)
Here is where you can download the manual
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Yes the problem can be undone also.
Feb 09, 2009 | Sharp R-540DK Microwave Oven
How to access touchpad
1. Unplug it from the outlet.
2. Remove any screws and unlatch any tabs in the vent grille.
3. Pull up and/or out to remove the grille.
4. Remove the screw now revealed at the top of the control panel assembly.
5. Lift up and/or swing down the control panel assembly.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
If you still have trouble, please reply back with your model number.
We repair these control panel assemblies.
Aug 27, 2008 | GE JVM2070 Microwave Oven
Sharp R-320H Microwave Oven Logo
387 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
