Question about Acer AL1716Bbd 17" LCD Monitor
Acer AL1716 blank screen but powers.
Okay heres the problem it powers on and shows nothing, i get a green power light and the back light of the monitor but there is no input signal, no visual display all it will do is blink every some odd seconds. I've used it with other computers and it doesn't work, I've also used it on my 360 (which was the intended use) but it will do just the same (note: I've used another monitor for my 360 and it worked just fine with my Xbox 360 VGA adapter) so as of right now I'm in a complete rut.
  • Aaron w Jan 07, 2008
    thank you very much.
  • Andoryu Apr 13, 2008
    I am having a similar problem. I plug the monitor in and it turns on for a split second, and then goes black. The power indicator light is on but nothing is on the screen. Would this be a problem with the driver or the monitor itself?
  • 233 Answers
Probably a bad inverter board, the inverter board powers the bulbs that display the image. this is VERY common problem on all LCD tv's,laptops and monitors.
usually a small transformer blows open on the inverter board. the innverter needs to be replaced if this is the this case.
Posted on Jan 05, 2008
Power light blinking, blank screen
Try it another PC and check the cable first, if still does not work, then you will need to open it up and look for bad caps with leaking/bulging tops/or bottom seals.
See failed ACER monitors here:
Failed TV and monitors: http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Please post back what you find.
Aug 30, 2010 | Acer AL1716 17" LCD Monitor
Light on power on switch keeps blinking, screen blank.
Definitely a problem with the monitor. If you can get the back open then look at the main board and the power board. You will want to look for puffy capacitors. Instead of a flat top it will look puffy like its pregnant.
If you find any like that then you need to replace them with new capacitors that have the same Uf rating and at least the same voltage or higher.
This will take some unsoldering and soldering skills. Make sure the stiped edge gets aligned with the striped edge on the board.
If you replaced them then the monitor should turn back on. If it doesn't then its a screen problem and you'll need to get a new monitor.
May 01, 2010 | Acer AL1716 17" LCD Monitor
Powers on, screen is black
Try it on another computer, if it still does not work, then you will need to open it up. More likely to have bad caps (leaking/bulging tops). Please see my pictures here so you will know what to look for inside.
http://s807.photobucket.com/albums/yy352/budm/ACER%20AL1716/
Please post back.
Apr 30, 2010 | Acer AL1716 17" LCD Monitor
Acer al1716 dont work
When the LCD monitor display flickers and or has a black screen then the fault is usually a faulty inverter or the CCFL lamp. When you look at the screen at a sharp angle and you see a dim image then it is a backlight problem and it is caused by a faulty inverter or a CCFL lamp.
Check out LCD Parts for parts, service, and DIY info. Use this link to their WEB site :-
www.lcdparts.net
Sep 03, 2009 | Acer AL1716 17" LCD Monitor
Acer AL1716 A Monitor does not start
The problem on your monitor is a bad power supply. Because of heat buildup in LCD monitors parts called capacitors overheat and blow out. You can go to our web site at:
www.ccl-la.com/badcaps.htm and see what to look for. If you open your monitor and see blown capacitors that look like the pictures on our site then replace the bad ones and you should be back going. Email me if you have additional questions or if you need to get the capacitors, we carry them in stock.
I hope this helps, if so please rate my solution.
Buddy
Corporate Computer
www.ccl-la.com
Aug 27, 2009 | Computers & Internet
My monitor is new .. the screen stays black and the power button flashes green ... how do i fix this ????
Hi!
I have acer al1716 LCD and whan the computer is turn on, the lcd led turn green but the lcd is showing black, what i can do?
thank you!
Apr 16, 2009 | Acer AL1716 17" LCD Monitor
Acer One Screen Won't Come On--
Hey,
if this computer is still under warranty you can contact acer to get a replacement or repair for it.
If you are outside of warranty there are a few things we can try, one unplug the battery and ac adapter for 15 minutes, plug in the ac power and try starting up.
if that doesn't work, call acer and confirm your warranty. if you don't have warranty we can try other things. if you do have warranty and the repair is free, use it.
Let me know if you need anything else.
Thanks,
Ekse
Feb 16, 2009 | Acer Aspire One PC Notebook
Acer AL1716 Blank screen & blinking green power LED
Hi..there,
You've got a busted backlight inverter... Need to replaced a new one...
Dec 17, 2008 | Acer AL1716Bbd 17" LCD Monitor
LCD Monitor wount turn on Black screen
my Acer AL1716 monitor will not come on after pressing the on button and no green light.
Aug 25, 2008 | Acer AL1716B 17" LCD Monitor
Acer AL1716 Power problem?
i have experienced the same problem (power cycles on and off and on and off... nothing but Acer logo and black screen) on 2 Acer model 1706 A version 1706 Ab monitors both built in July 2006. Before the customer reported the 2nd monitor with the same problem, i sent the 1st one into Acer for warranty service (after testing in on 4 machines w/4 different video cards). They shipped it back with a paper saying the monitor was repaired. I returned the monitor to the customer and it exhibited the same symptoms (aka, not repaired). Could there have been a bad batch in July 2006? When I plug a new Acer AL1716 monitor into the same computers, I have no problems at all.
Jan 18, 2008 | Acer AL1716 17" LCD Monitor
Acer AL1716Bbd 17" LCD Monitor Logo
355 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
