Heaters
Generic problem for all Heaters
30,000 btu kerosene ready heater
shared by 2 users
posted by satngtspcl on Jan 05, 2008
I have a ready heater that is pretty much automatic. Plug and play if you will.
it started to go bad a week or so ago and i thought i could solve the problem myself. Thinking logically, first i tested the polarity of the igniter and no problems found. I then cleaned and replaced the fuel nozzle, same problem.
Lastly i replaced the photocell and still can't keep it going.
Heater lights right away but goes out after about 20 seconds or so.
Guess I'm not a heater mech after all. Any suggestions will be appreciated. Thanks in advance.
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Posted by Guest on Jan 19, 2008
I've got a
55,000 BTU Forced Air Reddy Heater, have not used in a while, the ignition was turning on but that was it. it stopped 5 seconds after it startedit never ignites., the 2 valves on the back are kind of messed up.
Best Solution
posted on Jan 12, 2008
Helpful (85)
Buffalo12980
Rank:Wiz Wiz
Rating: 85%, 890 votes
check pressure of the air compressor should be in the 3.0 to 3.5 range. not enough won't suck fuel, too much will blow out the flame. igniter either lights or it doesn't no in between. does the main flame come on?
Rating Locked! (?) satngtspcl has rated this solution as Helpful
Thank You!
Was the solution helpful?
Show your appreciation by commenting on 30,000 btu kerosene ready heater:
I don't want to Accept this solution
Can you Help with these Heaters problems?
Heaters
The Patton heater model prh11 doesn't stop running
Leisure HOMEPRIDE Electric Fireplace Heater...
I need part #10000292 (top louve) for mdl #HEF33 ELECT....
Fahrenheat Electric Convector Baseboard...
i have checked the batteries ,the thermostat still will...
Holmes Products HFH111TU Compact Heater
The heater HFH111 that we have has stopped blowing hot...
Lakewood QT1 Patio Heater
I have searched the internet over & over and cannot...
Loading problems.
Repair Service
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
