make sure it is not set on air only,just went to a job and that's what it was lol.unplug dryer,take off bottom panel,on right side you'll see the heating element,pull off one of the wires and read out heater with a meter,if it's bad you'll need part number 3387747
Comments:
Nov 15, 2009
- also check thermal fuse located on top of blower wheel housing
Was this helpful?
Yes
No
Popular Solutions for Kenmore Elite 7.0 cu. ft. HE4
the front panel on our Kenmore elete has no power to it. The panel is just dead. There is power...
(More)
the front panel on our Kenmore elete has no power to it. The panel is just dead. There is power going to the washer but it is just dead. Is there a fuse in the washer that can be changed or something I can look at.
my washer stops in the middle of cycle and it shows 2 F, won't spin or drain. it keeps beeping what...
(More)
my washer stops in the middle of cycle and it shows 2 F, won't spin or drain. it keeps beeping what should i do?
the dryer is beeping and the lights are going all over the place and the dryer is not drying the...
(More)
the dryer is beeping and the lights are going all over the place and the dryer is not drying the clothes. I f we unplug the dryer, and plug it back in it will beep again. It did run for a short time, but starting beeping again. The vent is cleaned after each load.
My kenmore 110.27062603 gets stuck when 27 minutes left. Sets there and hums. Sounds like the drain...
(More)
My kenmore 110.27062603 gets stuck when 27 minutes left. Sets there and hums. Sounds like the drain pump. I can tilt the washer forward and it will drain and continue.
