Home | Zanussi | FLE1416W Front Load Washer | My wil 103 indesit won...
Zanussi FLE1416W Front Load Washer
Problem for Zanussi FLE1416W Front Load Washer
My wil 103 indesit wont pump out the water and the
By thomas_bragg on Nov 07, 2009
my wil 103 indesit wont pump out the water and the drum stops spinning quite quickly prior to spin, removed pump, guy at repairers says pump fine and it may be the board?
Solution #1
posted on Nov 07, 2009
Not Rated)
barkencoa
Rank: Guru  Zanussi Washers & Dryers  Expert
Rating: 89%, 1216 votes
If you have a test meter, and feel competent to do this, then select a spin cycle, and having set the meter to mains A/C voltage, test across the 2 wires going to the pump, if you are getting a supply, then it should be reading approx 240 volts.
If no reading, then, yes it could be the board, or a broken or loose connection.
Another way to do it is to select a Drain only cycle if there is one, and you should hear the pump running.
If you can, and it is still not draining, then check the outlet hose for a possible blockage.
Please rate my solution.
Thanks.
Was this helpful?
Yes
No
Popular Solutions for Zanussi FLE1416W Front Load
Questions and Unsolved Problems for Zanussi FLE1416W Front Load
Do you recommend Zanussi FLE1416W Front Load Washer?
Answer
Answer
my zanussi washing machine zwf 1221s jumps out from the wall when trying to spin. pump working belt... (More)
Answer
door light always on/start button flashing- machine not working
Answer
after the past few washes when i have taken the load out i have noticied dirty marks on them. these... (More)
Answer
we have just changed the ecu or main printed circuit board as u may call it! board on our zannussi... (More)
Answer
My GE Front-Load Washing machine (no model name, newer one might be called Adora) is about 6 years... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Zanussi FLE1416W Front Load...:
Top Washing Machine Experts
Rank: Guru Guru
Solutions: 14732
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Washing Machine Experts
Top Washer & Dryer Repair
(877) 477-7278
Washer and Dryer parts delivered overnight...
AppliancePartsPros.com
(800) 357-1234
Welcome to Action Appliance Repair. We have...
jay_action appliance repair
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
