Dell UltraSharp 1703FP - Flat panel display - TFT - 17" - 1280 x 1024 / 75 Hz - 0.264 mm - DVI, VGA ... Monitor
Problem for Dell UltraSharp 1703FP - Flat panel display - TFT - 17" -...
Screen got a quick white flash the goes blank
By ilove23dalat on Nov 07, 2009
Screen got a quick white flash the goes blank everytime you press power button _ What caused that problem ?
Best Solution
posted on Nov 07, 2009
Very Helpful)
scramblepad
Rank: Guru
Rating: 88%, 61 votes
Sounds like the cfl tubes are bad - they are like a shop florescent tubes very small that could be 2 to 4 tubes but most have just 2 - one on the top and one on the bottom that should also be replaced with the inverter - like changing your oil - a filter is replaced when you change your oil - this is not an easy task for the person that does not know much about electronics but can be done by yourself for about $50.00. The tubes last about 33,000 hours - on an average - 3 years but they could still go at any time - here is a site that will give you more information on it and show you how to do it yourself - keep in mind - your photo of the monitor may not be the same but the idea is the same for most monitors - you can get the tubes elsewhere for about $10.00 each not excluding shipping and they are very fragile - a slight bend and the tube is broke. Here is the site that will give you more information . They will have your tubes but you must take yours apart and measure the tube - they will show you how to do this also.
Hope this helped a little.
Kevin
[ here’s the link ]
http://store.lcdparts.net/
Was this helpful?
Yes
No
1 person thought this was helpful
Popular Solutions for Dell UltraSharp 1703FP - Flat
Questions and Unsolved Problems for Dell UltraSharp 1703FP - Flat
Do you recommend Dell UltraSharp 1703FP - Flat panel display - TFT - 17" - 1280 x 1024 / 75 Hz - 0.264 mm - DVI, VGA ... Monitor?
Answer
Answer
lg2234s monitor goes of blinking...cant turn monitor off (blue light remains off) then monitor turns... (More)
Answer
must turn on/off about 10 times before it stays on when I first turn the computer on
Answer
There is blank lines apperaring on the screen. The most recent one was preceded by a 'popping"... (More)
Answer
i have a orion 26 RTC MONITOR. THE POWER BUTTON USUALLY IS RED WHWN OF AND GREEN WHWN ON. NOW IT... (More)
Answer
My Dell Monitor 1703FP is experiencing momentary blackouts. The problem started last night and... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Monitors Experts
Top Computer & Laptop Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
