To set-up and secure the wireless router from unauthorized access, follow these steps: - 1. Connect the wireless router to your computer with a LAN cable. 2. Start your browser and enter the router's configuration URL IP address. (http://192.168.1.1) 3. Enter the router setup, login and password (login=admin PW=admin) 4. Change the admin password 5. Go to the wireless settings and change the default SSID and turn off SSID broadcast. 6. Setup encryption key the strongest is WPA2 (if not then WPA). 7. For further security measures - turn on MAC address filtering and enter the MAC address of the wireless cards on the computer/s you want to connect to this wireless router. 8. Record the settings you have made and keep it in a safe place and Save the settings. 9. Configure the wireless cards on the computer/s with the SSID and encryption settings of the router. 10. Remove the LAN cable between the router and the computer then the computers should be able to connect to the router wirelessly.
Hi, All the routers provides browser interface to configure it. You can configure your router right from your browser. For your router URL, check with its user manual as different vendor may have different address. Eg. 192.168.0.1 Then for configuration details you need to contact your ISP and get the same. Enter those details in your router config window. I hope this is useful to you.
to setup your Linksys router, just make sure that the router is connected to the network and has a DSL modem connected to it where you get your internet. Then make sure that the PC you will use is connected to the router. Then visit http://192.168.1.1 and you will be brought to your router's setup web page.
Comments:
Nov 07, 2009
- When you are the first person to set it up, then it has default credentials. user name: admin password: <leave blank>
I bought a used ADTRAN 612 - I have no idea as to what the ID/PASSWORD combo is. How do I resest...
(More)
I bought a used ADTRAN 612 - I have no idea as to what the ID/PASSWORD combo is. How do I resest this thing to factory defaults?
I have a 2006 BMW X3. US spec. I want to activate the daytime running lamps. Is there a way to do...
(More)
I have a 2006 BMW X3. US spec. I want to activate the daytime running lamps. Is there a way to do this without taking it to the dealer?
