Microsoft Xbox 360 Console
Problem for Microsoft Xbox 360 Console
This console has been banned for violations of the
By cameron_ftw on Nov 07, 2009
This console has been banned for violations of the Terms of Use. To protect the Xbox LIVE service and its members, Microsoft does not provide details about console bans. There is no recourse for Terms of Use violations.
How did this happen? I can't think of a reason why I got banned, how long did I got banned? can someone help me please?
Solution #1
posted on Nov 12, 2009
Not Rated)
lennypen1978
Rank: Apprentice
Rating: 0%, 0 votes
Hi im just wondering will this ban the virgin xbox of my friends??
Comments:
Nov 12, 2009
- hi i was wondering if this would ban the virgin xbox form xbox live??
Was this helpful?
Yes
No
Solution #2
posted on Nov 07, 2009
Not Rated)
nboulikas
Rank: Wiz
Rating: 89%, 14 votes
You must do the following to get access for free:
requires a virgin xbox that has not been banned (a friend's) and somewhat knowledge about computers.
Banned Xbox Live Fix - New EEPROM ' (Old Tutorial)
To get unbanned you need to purchase a new xbox EEPROM(pal or ntsc). Steps for installing it are listed below. IT WORKS. Just make sure your orginal MS info is correct and your modchip is turned off.
GETTING THE EEPROM FILE FROM THE UNBANNED XBOX
(TO INSTALL YOUR EEPROM, MAKE SURE YOU ARE USING CONFIGMAGIC FINAL* ALL OTHER VERSIONS ARE BUGGY AND WILL CAUSE PROBLEMS. ALSO, DO NOT USE THE SOFTWARE: EEPROMER)
[This is only if you want to backup your original eeprom file]
1. In EvolutionX, do the "Backup" command in the Utilities menu. It will generate files about your Xbox specs.
2. FTP in your Xbox, or use a file manager tool, and in C:Backup, you will find a file called EEPROM.BIN
3. FTP that to your PC HD or remember its location for future reference.
SETTING UP THE FILE FOR CONFIGMAGIC FOR THE BANNED XBOX:
1. Once you have Configmagic loaded onto your HD or on your PC, there will be a directory in it called DATA.
2. Move the EEPROM.BIN file, the new unbanned EEPROM you purchased, into that DATA directory, overwriting the EEPROM.BIN file that is already there.
3. If you are making a Configmagic CD, you can now make the ISO of it and burn it. Xbox HD users, don't worry.
RUNNING CONFIGMAGIC:
1. Load up Configmagic.
2. A warning screen will be shown, press "A" to bypass it.
3. When Configmagic finally loads, it will show your current EEPROM on your Xbox. Make a note of the DVD KIT ZONE and VIDEO AND XBE REGION information. "NTSC, Region 1" for US Xbox gamers "PAL, Region 4" for UK Xbox gamers
4. Select "LOAD XBOX EEPROM" in the menu.
5. Select "UNLOCK HD" in the menu.
6. Load the EEPROM.BIN file in the DATA directory by choosing "LOAD EEPROM FROM .BIN FILE"
7. If you see that the VIDEO AND XBE REGION information is different, you MUST change it. Go into the menu and choose "ON-THE-FLY EDIT EEPROM". Change the VIDEO AND XBE REGION number to the proper information of your former EEPROM.
8. Now, select "UPDATE XBOX EEPROM" in the menu.
9. Your Xbox's EEPROM will now be updated with the file in the DATA directory.10. In the menu, select "LOAD XBOX EEPROM". You will notice your EEPROM is now different! Success.
11. Select "LOCK HD" from the menu.
12. Select "EXIT CONFIGMAGIC" in the menu.
IMPORTANT TIPS:
- If you were using the XBOX DVD KIT to play DVDs, and the Xbox gives an error about region, load up Configmagic and change the DVD KIT ZONE number to the number of your previous EEPROM. UNLOCK the HD, choose "ON-THE-FLY EDIT EEPROM" in the menu and simply change the DVD KIT ZONE number. Then, UPDATE XBOX EEPROM and LOCK HD. Exit Configmagic.
- You can view any Xbox EEPROM using your PC by getting Liveinfo PC program. It will show all the details of an EEPROM.BIN file. You might find it easier to edit any possible changes to your DVD KIT ZONE or VIDEO AND XBE REGION using the program, rather ON-THE-FLY EDIT EEPROM in Configmagic.
- Sometimes, with a PAL EEPROM, your Xbox's time might be wrong or video settings will be different. Go into the MS dash and change the settings to the way you seem fit.
Special Notes:
- If you were banned with your original eeprom, once you replace your eeprom, you will need recover your account. To do this, simply select the account recovery option. Once this is done, you will need to verify some personal information in order to retrieve your account.
Was this helpful?
Yes
No
Popular Solutions for Microsoft Xbox 360 Console
Questions and Unsolved Problems for Microsoft Xbox 360 Console
Do you recommend Microsoft Xbox 360 Console?
Answer
Answer
my screen keeps on freezing just before the title screen.
Answer
mine does the same asks for me to open tray all you have to do is turn it off, turn it on its side... (More)
Answer
my screen freezes before it gets to the title screen
Describe your Video Game Consoles problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Video Game... Experts
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
