Question about One For All URC4220 Remote Control
Remote volume I am having trouble having the volume to go up and down when I am on satellite mode I only get it on tv mode how do I get it so it will work on satellite mode thank you
    Novelist:
  • 129 Answers
Hello, follow this link to download the manual and the codes for your remotes:
http://www.ofausa.com/remote.php?type=URC4330
just right click and save as on the download links.
if this does not work you can try the search method,
you do this by either holding down the device button eg: TV or if you have one the "magic" button for three seconds, a light should then flash twice to say you have done this correctly.
then press the keys 991 then the power button.
you must now press the channel up key (ch+) possibly upto 150 times while the remote cycles through every code.
Once your tv or device switches off stop pressing the ch+ key and press the power button to make sure it switches back on,
(if you press ch+ too many times you can go back by pressing ch-)
When complete press the magic or device key again to save the settings (light should flash twice to confirm)
You may want to set up the "push through / punch through" this allows you to change the tv volume while still in the satellite mode, this should be in the manual.
Many thanks
Mark
(www.sparky-uk.com)
Posted on Jan 06, 2008
My remoute control joust change the volume and anyother keys doesn't work.
The remote's volume keys are "punch-thru" keys, meaning they'll work for the TV for which the
remote is programmed no matter what mode the remote is in. It seems your remote is not
in "TV mode," but the punch-thru keys (volume UP/DOWN) are working.
The Solution: change the remote from "AUX mode" or "DVD Mode" back to "TV mode", by
pressing the "TV" button at the top of the remote.
Either that, or your remote keypad has failed with the exception of the Volume UP/DOWN keys....
Also, your batteries may be failing, since it takes a tiny amount of energy to light
the IR (infra-red) LEDs at the front of the remote to change the volume.
Is your remote a "multi-function" remote?
Could help more if you could post your Samsung remote model number, since
www.samsungparts.com lists 37 pages of TV remotes (at 10 models per page).
Jul 02, 2011 | Samsung TV Remote Control
I have a Sony Bravia TV, only a year old, had several power outages and suddenly RM-YD028 TV remote is not working at all. On the Dish network remote, the satellite controls are working, but not TV...
If neither the DISH Network remote or the TV remote is working for you most likely your remote sensor is going bad. If you'd like to try readdressing the remote follow the steps and procedures below. Codes: 500, 837, 125, 808, 798, 640, 796, 783, 795, 797, 865, 846, 842, 563, 501, 810, 841, 781, 807, 838, 690, 758, 843, 845, 591, 839, 806, 840, 844
To program the remote:
1.) Hold the clear "TV" mode button for four seconds or until all four buttons at the top of the remote are lit.
2.) Press one of the three digit codes listed above followed by pound (#)
3.) Check for functionality by trying the volume power and mute.
Be sure to press the "SAT" button to return to satellite mode if the code works.
Daniel Busa
DISH Network
Customer Service
May 31, 2011 | Sony RMYD028 Remote Control
Toshiba 32a33. I'll be watching tv and the volume bar shows goes down to 0 (no sound) when it is in this mode the remote control will not work on the volume, you can get up and manually up the volume...
1st check to see if your remote volume down button is stuck. 2nd do you have wireless internet (router) or any other wireless devices phones,ceiling fans, another Toshiba remote, if so try unplugging them (or remove the batteries if it's a remote) while it's changing the volume one at a time. If a different device makes it stop try changing the channel on it. Also make sure the t.v doesn't have a mind of its own and remove the batteries out of the t.v remote, let it ride for a couple days if it happens without the remote being in play then you know your t.v is acting strange, if it stops then starts back up when you start using the remote again then you know your dealing with a remote issue. Sometimes Freq.'s merge causing remotes/wireless devices to conflict with each other.
May 18, 2011 | Toshiba 32A33 32" TV
Waiting on a remote(since we purchased TV in DECEMBER!) Missing from box!! Stuck on home mode or store mode - soooo frustrating with no remote!!
HI, it is possible to operate most of any flat screen t.v.'s function using buttons on t.v. These are marked as follows: + and - are for volume and when in the menu for either moving up/down or to the left and right, the < and > are to change the Channels ( also used in menu mode to scroll either up and down or to the left and right ), then you should have a button marked INPUT, maybe A/V this switches between your sources ( the t.v.'s tuner,cable,sat,p.c. input,dvd,aux,hdmi,and so forth,then you have a power button and last but not least the MENU button to adjust it. also if you have a remote for a cable/satellite box with a manual it may be able to operate an APEX( pretty common actually ) if no manual for said remote-cable/satellites customer service have been know to help quite readily. I hope this has been of some help, good luck, Prodzilla
Apr 01, 2011 | Apex Digital LD4088 LCD TV
I have a coby dvd/cd home theatre system i have hooked it up to satellite but when i turn it to tv the volume can't be controlled only can lower volume in dvd mode not in tv and the tv remote can't turn it...
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
Jan 16, 2011 | Coby CSP92 Theater System
I have a viore tv dvd combo need codes for it
You probably have the same problem that I found after I'd purchased my Viore TV (LC 26VF59), your cable box remote or dish network remote doesn't have the Viore codes built in. Bummer. I looked around and couldn't find codes for my Viore. Doubt you'll find them for yours. Here's a helpful suggestion I read about that works for me:
I bought for $20.00 a Sony RM-VL600 Easy Learn remote control from my electronics store. It's EZ because you only have to place the Sony head to head with the Viore remote, press TV setup and follow Sony's instructions to have its remote catch and learn the codes from your Viore remote. I only programmed my Sony for the Power On/Off, Vol Up/Down from my Viore remote. You back out of Setup and now your Sony will control the TV for those functions. Next you get your cable box or satellite remote put it head to head with the Sony remote, press the CABLE or SATELLITE set-up button on the Sony and then have it learn all the C or S functions you want from that remote. You do program in this mode the Power On/Off button, but you don't program the Vol Up/Down. The volume for the TV will work when you're all finished and operating under the Cable or Satellite button on the Sony remote.
Now, you press the TV button on the Sony and then the Power button. The TV turns on. Now you press the Cable or Sat button and then the Power button and the Cable or Sat box turns on. Like I said, even though now you are operating the Sony remote under the Cable or Sat button the TV volume instructions carry over to this side of the remote so you don't have to switch back to the TV button to raise or lower volume of the TV.
When I'm done watching, I hit the Power off and the cable box turns off. I then hit the TV button and again the Power off button and the TV turns off. So, it's a little inconvenient when starting and stopping, but at least you are using only one remote.
Hope this has helped.
Nov 19, 2010 | One For All URC-3021 Remote Control
No audio on model at1308 good picture but no sound....thanks mel
there is no sound on your TV because the sound IC is faulty.
You can open the TV an read the sound IC with a meter or just take the TV to a repairer to fix the problem for you once and for all.
Take care.
Mar 11, 2010 | Apex Digital AT2402 24" TV
Cannot program tv using bell satellite remote
Turn your TV on.
Press and hold the TV mode button until all the other mode buttons light up.
Press the blank POWER button. (If your remote only has one POWER button, press that one)
Press the UP ARROW button repeatedly until your TV turns off.
Press the POUND (#) button to confirm.
Cheers
Feb 01, 2009 | Hitachi 50FX30B 50" Rear Projection...
MAGNAVOX PR1910 C125
try pushing the up volume button and the down volume button at the same time.
Jan 03, 2009 | Philips 28PW6506 28" TV
RCR311W Rmote will not change tv channels
It appears you need to program the satellite device code back into the remote. Has this worked for you before or just started this trouble out of the blue?
You can some times have the satellite providers install the remote or insert the code information for you [for free most of the time] otherwise you can contact the satellite provider directly for the discrete coding based upon your remote control.
Keep us informed on how things go for you. Thanks!
May 24, 2008 | RCA RCR311B Remote Control
One For All URC4220 Remote Control Logo
75 people viewed this question
Top One For All Televison & Video Experts
Computer Repairing
Computer Repairing
Are you an One For All Televison and Video Expert? Answer questions, earn points and help others
