Remove rear access panel, and remove the drive belt.
Spin drum by hand, and if it feels rough or noisy, then the main drum bearings have failed, if no noise, then check motor for noise, if no noise, check the concrete wieghts are not loose, and that the dampers are not broken or worn.
Please rate my solution.
Thanks.
Was this helpful?
Yes
No
Popular Solutions for Hotpoint Aquarius WD640 Front
hi my wd 640 comes up with fauilt F13 and leaks a little water which shows in front of the machine....
(More)
hi my wd 640 comes up with fauilt F13 and leaks a little water which shows in front of the machine. whats wrong? thanks for your reply chris
As this wd640 is a washer dryer, im sure there must be a filter some where I need to clean etc but...
(More)
As this wd640 is a washer dryer, im sure there must be a filter some where I need to clean etc but dont know how to find it or go about it.... Had a manual but cant find it... thanks Elaine
