Parts I need the small power supply off the power cord inlet board, I have all the numbers if needed.
  • 1,067 Answers
Btx power supply ? buy one on new egg .com cheap ok
Posted on Jan 10, 2008
My dv2175ea power inlet faulty
Most power cord ports are soldered directly to the mother board. Open this one up and see if it is a separate part or not. If it is, you could probably just replace the small part, but my bet is that it would take an entire system board replacement.
Nov 12, 2012 | Computers & Internet
Power light flashes but wont turn on I was told it is making a high piched sound frome the power supply and needs replacing. I want to replace it myself or rather my son will what part number do I need to...
It sounds like you have a short in your power supply. Sony have problems with these parts going out:
but if you are not familiar with electronic repair you would have to look at your power supply and get the exact number off it to compare with these:
hope this helps
Feb 22, 2011 | Sony Televison & Video
I have a philips 30pw8420/37 that will not turn on at all. no matter how long i leave it unplugged or how many times i try to unplug and re plug, the tv will do nothing at all. no error lights anywhere. so...
begin with the power supply board, check for blown up fuse, work your way up to the power mosfet, its the part thats being bolted to an aluminum heatsink, check for drain/source shorts, if confirmed replace it with the same part number, check also the secondary side of the power supply board, look for open current fuses, they look like a small (TO-92 package) transistor but have only two pins, if there is continuity it is good, otherwise replace it with the same rating, hope this helps
Feb 04, 2011 | Televison & Video
10 Blink when you plug it in. Power supply? Where do I buy one and what is part #?
Take ur tv aparts and the power supply board have a serial number on it.That the board,where the power a/c cord plug into it.Try website like search Panasonic TH-42PX500U plasma tv power supply board.Will,see many refurbish power supply board for sale.
Sep 15, 2010 | Panasonic TH-42PX500U 42 in. Plasma...
My Panasonic Viera TH-42pz700u will not turn on, no red lights at all. I was out of town for a few days to come home to this problem. I replace the power supply board and still nothing.
Good day sir, hi, at this point, you have no choice but to bring it to a service center, replacing the power supply board is not the faulty part, you may need to measure voltages, from the ac mains to the board and to its power output to the entire TV. There are several possible fault part;
  1. the power cord
  2. the power switch
  3. the ac inlet that accepts the power cord to the board.
If these things are thouroughly checked then you have no choice but to get professional help from the service center or dealer.
Nov 06, 2009 | Panasonic TH-42PZ700U 42 in. Plasma...
Kde37xs955 sony with sound but no pic
This tv uses two power supplies. Do you hear a high pitch squeal? If so replace the small G power supply. If not make sure fans turn freely and finally change the large power G board. Look for obvious hot spots and swollen caps before buying board as the small bd. is approximately 129.00 and the large even higher. Part numbers on stamp on each board.
Hope this helps: Sam Farrell
Oct 07, 2009 | Sony KDE-37XS955 37 in. Plasma HDTV
Power board part number
It's unclear which board you are referring to, so I'll include the likely two.
Parts 4120-6201-05 and 4120-6202-05 are both labelled "Power Supply (PU1)". I believe this is likely the board you are referring to. It is the small orange board in the top-back of the printer. It is unclear why there are two part numbers for it. However, I suspect they may both be for the same type of board with one containing optional, upgraded components.
Part 4120-0109-04 is labelled "PWB Assy (PWB-A)". I am assuming this means power board assembly. It is the small board in the back of the printer, in the lower-left (looking at it from the back). This does not look like it would be called a power board. It looks more like a logic board.
Jun 06, 2009 | Minolta magicolor 2200 DeskLaser Printer
ASUS Crosshair won't boot
some motherboard have 2 power supply plugs 1 for board 1 for cpu check and see if yours is like this 1 is a wide one with about 15/20 pins in the other is asmall square one with 4 pins
Jul 25, 2008 | ASUS CROSSHAIR Motherboard
GE D52GW12 52 in. Rear Projection HDTV-Ready Television
The ITC222 chassis actually has two different boards that are related to the power supply.
(1) Main power filter board #MIS222E0000.00
(2) Power supply #PP222E0000.37
The first board is a small board where the power cord enters. The second board is the large board that the small board plugs into.
Apr 08, 2008 | GE D52GW12 52" Rear Projection HDTV-Ready...
I9900 will not power up at all
Make sure the power cord is plugged into a live outlet. If it still will not power up check the power supply. I have heard those power supplies go bad and they can be replaced.
Jan 21, 2008 | Canon i9900 InkJet Photo Printer
Computers & Internet Logo
48 people viewed this question
David Payne
David Payne
