Question about SanDisk Sansa c250 (2 GB) MP3 Player (SDMX7-2048)
Device doesn't recognize my 2gb expansion card anymore.
The device recognized it two days ago and showed all the albums in windows media player, now both the device and media player says there are no files. Yet, when i plug the micro card directly into my computer, it shows all my music as .dat files.
  • Anonymous Jan 07, 2008
    when i plug in my mp3 player to get music, it says it doesn't reconize it. i read online to change my settings from MTP to MSC. but, i can't find settings on my computer. and, my instructions say that the computer will say Sansa Clip when i get onto my computer. any help?
  • Rocket-Flyer Feb 14, 2008
    I recently added a 2 gig card to my C250 player. The player does not reconize the additional 2 gigs of memory. When I plug in the play to the computer to add songs or sinc it, the available memory only adds up to the original 2 gigs built into the player. I tested the card and it reads and writes data fine. It's just that the player will not read or acknowledge the additional 2 gigs.
  • 8,596 Answers
Stilts - this player can't actually handle an SD card greater than 256 MB unless the player is largely empty - sad but true
everyone else -
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the "MTP Device" by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on May 25, 2008
6ya staff
SOURCE:
Not recognized by my laptop
Good morning, afternoon, evening or night; whatever time of day you are viewing this solution post. Thank you for choosing FixYa to assist you. Your computer is not recognizing your Archos Vision A14VG Digital Media Player? The computer should be able to recognize it because your digital media player is compatible with the three major operating systems: Windows, Mac and Linux. Maybe a Firmware or driver update will help.
  1. First, make sure your laptop has USB 2.0 hi-speed ports installed on it (If you are not sure if these are installed on your laptop, check your laptop's user manual).
  2. Connect your Archos to your laptop.
  3. On your laptop, go into Device Manager and expand the Universal Serial Bus Controllers group. Double click each device in that group until you find your digital media player.
  4. Update the driver.
  5. If it doesn't need an update, click try uninstalling the driver then reinstall it again.
If the computer still doesn't recognize your device, Try these websites to see if the device may need a firmware or driver update from there.
http://driverwhiz.com/drivers-en?brand=Archos&logo=Archos&subid=1001-us-en-10000048213&gclid=COOT2e-vgakCFYg32g but with with with oduyB-Sw
http://www.easydriverpro.com/lpd/drivers/drivers-en.php?sr=1&ci=500&agid=1349&ad=5825&kid=1349&gclid=COfRup-wgakCFcPt7QodeUzXTw
If your computer is still not recognizing it, try connecting your device to a desktop PC. If the desktop PC recognizes your device, then the problem is coming from the USB ports on your laptop. They may not have the amount of power needed for the device to connect to your laptop. If the PC desktop doesn't recognize the device, then the problem is that one of the drivers in the Archos is defective (not working anymore). Once that happens, the only way the device can work again is if the defective driver gets replaced. If your warranty for the product is still in effect, send the product back to its manufactuer and have them look at it. I hope this is just a driver updating issue. Thank you for choosing FixYa to assist you with your problem. Have a good day evening or night; whatever time of day you are viewing this.
May 24, 2011 | Archos Vision A14VG Digital Media Player
I baught a Sensei 2GB mp3 player. Pink. When I ...
You need to turn on the device and then it will be recognized.
May 21, 2010 | Audio Players & Recorders
Sansa MP3 recognizes 8 gb micro sd card as a 4 gb card
your reader does not support the 8gb device, look for firmware upgrade for the reader
Jun 29, 2009 | SanDisk Sansa e260 MP3 Player
Archos 405 2GB isn't recognized by Windows XP computer anymore
Hi. Remove the 16gb SDHC. If you still have difficulties then downgrade the firmware (to original version). You may need to enter
'recovery mode' by powering down the archos then press both power button and volume up button at the same time. Do a disk repair. Shayind4
Jun 28, 2009 | Archos 405 Digital Media Player
Window media player is not recognizing my sansa m230
Refresh drivers - connect player to PC. Right-click My Computer & select Manage. Click Device Manager on left pane. Player will show on right pane as USB Mass Storage device or Portable Device.
If there is a yellow exclamation point (!) or question mark (?) beside the device, try to refresh the drivers: right-click the entry with the error & select Uninstall. On top menu, click Action then select Scan For Hardware Changes.
Feb 21, 2009 | SanDisk Sansa m230 MP3 Player
Computer doesn't recognize Zen Vision:M
just connect it using another USB data cable
it ll surely work
tc
Nov 02, 2008 | Creative Labs ZEN Vision:M Digital Media...
Siren MP3 player not recognized by Windows Explorer‏‏
Installing the latest Windows Media Player solved the problem.
Oct 02, 2008 | Siren Edge MP3 Player
Weird Random Happenings
if you're constantly updating your database of music or you're constantly making changes toyour files then your media player may be trying to update itself unsuccessfully, unfortunately this doesn't offer the option to automatically erase your old files. Under your media and synching options try to turning off your auto-synch option. Disabling this option or making it manual will have the disadvantage of not updating your subscribed music, but may keep songs that you already have in your database and on your media player from doubling up.
May 17, 2008 | SanDisk Sansa e260 MP3 Player
Expansion card
The issue with the card is not song format as you said it's the card format. When you put you're it into the CPU I?m assuming that you clicked yes on the warning/and or problem window and it formatted it to the CPU. So what you need to do is find what format the hardrive /and or internal memory is and format the card to that.
Oct 25, 2006 | SanDisk Sansa e130 MP3 Player
SanDisk Sansa  c250 (2 GB) MP3 Player (SDMX7-2048) Logo
Top SanDisk Audio Players & Recorders Experts
Joe Negus
Joe Negus
Ekse
 Ben
Ben
Level 1 Expert
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
