Rain Recording LiveBook L4 Digital Audio Notebook PC Notebook
Packard bell Easynote L4 won't turn on
shared by 2 users
posted by nipperthedog on Jan 05, 2008
Packard bell Easynote L4 won't turn on. No lights, sounds, nothing. Took battery out plugged in adapter....nothing. Kept adapter plugged in to see if it got warm...it did. Adapter must be working then. Any ideas?
Comment posted on Jan 05, 2008
Are you saying it may have blown its cpu? OMG
Comment posted on Jan 06, 2008
Borrowed a mate's multi-meter, power adapter no good. Problem solved.
Comment posted on Sep 26, 2008
Bought a new power adapter from ebay (about £15). However, a couple of months later, tripped over the lead while it was plugged in and it wasn't long before the laptop was dead. I had damaged the dc jack and it needed replacing. Bought a new one from ebay (about £5), googled for some disassembly hints, bought a disassembly manual from 9manuals and took laptop apart. Once the motherboard was out I got an electrician friend from work to do the soldering. There are sites that talk you through this step in great detail though (http://www.laptopsockets.co.uk/new_jack_range.htm). This seems to be quite a common problem with laptops, but cheap to fix if you attempt it yourself. Mine has been back up and running again for 6 months now.
I have the same problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
1 Other User Has The Same Problem
Posted by oryan86 on Sep 18, 2008
I have the same problem.
what do you do now you've realised your power supply is no good?
which bit is no good; the fuse in the plug? the AC Adapter cuboid?
Best Solution
posted on Sep 24, 2008
FixYa! (100)
la_chique
Rank:Apprentice Apprentice
Rating: 100%, 2 votes
I've just fixed one of these for a customer. The problem in their case was a damaged DC jack. Very fiddly to do, but definitely fixable!!
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on Packard bell Easynote L4 won't turn on:
I don't want to Accept this solution
Best Solution
FixYa! (100)
BADBOYJAY
Rank:Wiz Wiz
Rating: 83%, 56 votes
it sounds like your power supply is no good or the chip in side your laptop has over heated
Rating Locked! (?) nipperthedog has rated this solution as FixYa!
Thank You!
Can you Help with these PC Laptops problems?
PC Laptops
the laptop would nt turn off so i unplugged it and let the...
PC Laptops
Bought new laptop, also bought matching HP bluetooth...
PC Laptops
If you use a flash light on it you can see the picture.
PC Laptops
i have problem of powe on password with my laptop compaq...
Loading problems.
Repair Service
Find PC Laptop Repair Service Provider Near You:
Browse the Repair Service Directory
Repair Service Providers, Get Listed FREE
Prescreened Contractors
Get Matched to Prescreened Computer Professionals
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
