Ipod Password Lock
The first way is you can connect the iPod to the computer it was originally configured on, and open iTunes. When you disconnect iPod from the computer, it will no longer be locked. You then can go into the preferences and turn off the lock. If you don’t have access to the original computer or it just does not work, you can jump to the second method. The second way is the fix for any iPod problem, it is the classic “restore your iPod to factory settings.” That this will erase all data on your iPod and take you back to day one, but you can just add your music and data back to iPod from iTunes. Good Luck, I hope this helps
Was this helpful?
Yes
No
Popular Solutions for Apple iPod Video 30 GB Black
screen is frozen,on the top of the screen it says SDRAM full test,tells me to please wait...........
(More)
screen is frozen,on the top of the screen it says SDRAM full test,tells me to please wait........ RUN: bl on PASS:bl blink FAIL: bl off Reset to continue. but the screen is frozen so can't reset etc,help.-
apple ipod classic 30gb says to restore and after its done restoring it says failed. and then says...
(More)
apple ipod classic 30gb says to restore and after its done restoring it says failed. and then says to format disk but fails that also
ipod video wont power up all it does is you can slightly see it come on when you plug it in and...
(More)
ipod video wont power up all it does is you can slightly see it come on when you plug it in and thats it
