I have a lot of photos that i would like to put on a cd so that i can print them out at walt mart. but how do you transfer pictures into a cd? and is it possible??
Hi, you need cd/DVD writer and NERO software installed inyour OC to do that. Just open the nero cd/dvd writer software. select new data disc. add all your picture files to it. put an empty CD in the tray.click on Burn button. That's all. Get this CD to walt mart to get these printed. I hope this is helpful to you.
Hello! It's certainly possible if you have a CD burner. To see if you do, check the drive to see if it says CD-R, RW, DVD-R or DVD-RW.
Put all of your photos in one folder. Click anywhere in the folder, and press ctrl+a to select all. Right click in the folder. Send To > Select your CD drive.
If you're using Windows Vista, it'll automatically eject your CD tray so you can put in a blank disc. Put your blank disc in the drive and close it back up.
Use the burn wizard to burn the disc, and finalize it so that it can be read on all computers.
Hi, I have a Toshiba Satellite P200-156. The screen isn't working (back-light flickers on start-up,...
(More)
Hi, I have a Toshiba Satellite P200-156. The screen isn't working (back-light flickers on start-up, a couple of times, and that's it), however, when plugged into an external monitor, it does show the desktop; Very low resolution, very poor colours, alot of missing textures too & distorted images; On start-up, text is not right, with extra 'bits' added onto most letters & vertical lines over entire screen. I was guessing that the graphics card was dead since the built-in screen wasn't functioning at all, however, the VGA port for the external monitor does't work properly either with its problems (as described) and it's connected to the motherboard. The graphics card doesn't appear in device manager, but the standard VGA adaptor appears instead. I tried installing the most recent drivers for the graphics card, but on start-up, it just crashed with a blue-screen. When I booted in safe-mode, the GC appeared in the device manager instead of the VGA adaptor; I rolled the driver back so that it would work on start-up again, and it reverted back to the VGA adaptor. Could this be driver related at all, or is it hardware? Thanks
CD/DVD drive stopped working within my Sony Vaio PCG-7H1L laptop. When I put disk in, light comes...
(More)
CD/DVD drive stopped working within my Sony Vaio PCG-7H1L laptop. When I put disk in, light comes on, but disk is not spinning. Does this mean I need new CD/DVD drive or is there some type of belt that needs replacement?
my curser will not move. I clicked function key and the lock and it goes to a screen where the only...
(More)
my curser will not move. I clicked function key and the lock and it goes to a screen where the only thing showing is an owner locked icon and words owner lock. the curser will move on this screen. if I click owner lock it goes back to the locked screen
the internal mouse pad will not turn off...even when you hit the button below space bar and the...
(More)
the internal mouse pad will not turn off...even when you hit the button below space bar and the slide bar to the right of the mouse area does not work
