Question about Sony Grand WEGA KF-50WE620 Television
Sony KF-WE50 Hi There, There is no picture or sound on my Sony Wega LCD rear projection TV but the front red light flashes 6 times. Appreciate your assitance. All sound and image shut down yesterday when listenning to TV. When I try to turn it on, the "power/standby" light flasnes green for less then 20 seconds then turn red and flashes 5 times for a minute then turns off (the fan stops). What is going on ? Can you help me? Thank you Patrick Chagnon
  • 4 more comments
  • Drighten May 10, 2008
    My TV is having the same problem, the green light flashes 46 times, then the red light flashes for 120 times, then it just shuts off.. Occasionlly I hear a slight buzzing sound from the back, but its infrequent.
  • Anonymous Jun 09, 2008
    My SONY does the same...Flashes green for about 7 to 8 times then goes red.....I get a red lamp light ont he front....also..
  • Anonymous Jun 15, 2008
    same problem
  • bellmondo Oct 23, 2008
    My TV is having the same problem, the green light flashes 46 times, then the red light flashes for 120 times, then it just shuts off.. Occasionally I hear a slight buzzing sound from the back. PLEASE CAN U HELP?
    THANKS
  • wham7124 Nov 16, 2008
    TV works for a few minutes then shuts off
  • Anonymous Nov 26, 2008
    three red flashes bulb is secure and light still flashes
It may be your lamp,,,,,,,,,,,,need to change it
Posted on Apr 27, 2008
My front panel sound is not working.......?
how i can do this.?
Posted on Jan 05, 2008
Sony LCD Model KF-60WE610 lamp was replaced and then it shortly after stopped turning on. Blinks Green 6 times then Red 6 times Please help!
For Sony Model KF-60WE610, KF-50WE610, and KF-42WE610, the Diagnostic Code of power light indicator flashing 6 times green, then flashing 6 times red (6 red etc), means you need to replace part number A-1302-272A G1 BOARD, COMPLETE. See Sony Service Manual, 4. Chasis-1 at part Ref no. 103. The Power Board sits vertically in two slots on the left side of the electronics board. 4 wire connectors to remove when replacing. This component fits all 3 KF models listed above.
Jun 22, 2011 | Sony Grand WEGA KF60WE610 60" Rear...
I have a SONY KF-WE50 rear projection tv, a few weeks ago it started to turn the pic and sound off while the green light was flashing around 30 times. After the light finished flashing both the picture and...
the green is the reboot process and is normal.
the red light is an error code indicator.
count the blinks of the red light...it cant be 30 times (I think)
it will blink a sequence, pause, then do it again for a total of three times.
count carefully, it gives you three chances to catch the number it is blinking.
Apr 13, 2011 | Sony Televison & Video
SONY GRAND WEGA LCD PROJECTION TV Model KF-WE50 Lamp model
Go to MCM.com . You can get a Philips replacement bulb for $99.00. You have to remove it from the holder.
Apr 01, 2010 | Sony Grand WEGA KF-50WE620 Television
Sony Grand Wega KF-WE50, no LED lights, wont turn on, fuse is OK ?
Try plugging into another known good wall outlet. if still not standby light then the power board needs replaced.
Mar 30, 2010 | Sony Grand WEGA KF50WE610 50" Rear...
Picture went out and red light flashes 6 times then stops a while and blinks 6 more times
Something is not sending the proper signal telling the tv to start up. Most likley is the thermal fuse on the optical block. Could also be a bad fan or even a bad lamp. Good luck
Dec 10, 2009 | Sony Grand WEGA KF-42SX300 42" LCD TV
Sony Wega KF-42E200A Projection Bulb
New bulb is just fine.
3 blink shows that lamp cover after replacement of bulb in TV is not fixed properly or not seated well in its position.
Put new bulb and carefully place back lamp cover in its position because lamp cover will press tinny safety switch inside that will send signal to system control of TV that lamp is installed properly.
Turn On TV and get vivid picture of Sony.
Thanks.
Oct 17, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
SONY GRAND WEGA KF-50WE610 can't turn on TV screen.
Ths 5 blinks usually indicate an AKB problem. There is a break in the video path. I'll look up your specific model and post the results here. Please update this if you wish to attempt the repair yourself.
Thanks,
Dan
Mar 19, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony KF-WE50
Hello Failrlane.
You have a bad thermal fuse. You must remove the back cover in order to fix this unit. The thermal fuse can be found near the lamp housing. part number for kit: A-1137-954-A
Best regards
Circuitcity
Jan 03, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Televison & Video Logo
521 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
