Sony Grand WEGA KF50WE610 50 in. Rear Projection HDTV-Ready Television
Problem for Sony Grand WEGA KF50WE610 50 in. Rear Projection...
Tv just switched itself off,and the power light
By kate_scott on Nov 07, 2009
Tv just switched itself off,and the power light flashes red 6 times,but it wont turn back on
Solution #1
posted on Nov 07, 2009
Not Rated)
techman007
Rank: Guru  Sony Televisions & Videos  Expert
Rating: 90%, 91 votes
The thermistor on the lamp housing has failed, it is used to report the temp of the lamp during operation, The only way to replace it is to remove the optics engine and replace the part. Look for a two wire connector coming from the lamp housing assembly. On this model the thermistor is out of date and needs to be replaced with a newer type. You can jumper the termistor with aligator clips but you risk the unit not shuting down if temp gets to high. I dont recommend u do this but is is an option for you, if no other problems with temp has ever occured before. This will at least let you watch the television normally until the part is replaced. But just because this will work do not you do not need to replace this part ok. Also replace you lamp at this time also..
Was this helpful?
Yes
No
Popular Solutions for Sony Grand WEGA KF50WE610 50
Questions and Unsolved Problems for Sony Grand WEGA KF50WE610 50
Do you recommend Sony Grand WEGA KF50WE610 50 in. Rear Projection HDTV-Ready Television?
Answer
Answer
We had a problem with heavy candle soot throughout our house several weeks ago. The picture on our... (More)
Answer
My Sony Grand Wega kf50we610 takes like 10 times to try to power on before it actually turns on and... (More)
Answer
I recently changed out the lamp because my tv went out within the last year. Now my tv's picture... (More)
Answer
power/standby light flashes 6 times television will not turn on
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Sony Grand WEGA KF50WE610 50...:
Top Projection Television Experts
Rank: Guru Guru
Solutions: 773
Experience: 30 Years of professional repair and design.
Ask Me
Find more Projection Television Experts
Top TV Repair
(859) 609-2887
SERVICE/REPAIR OF TELEVISION AND ELECTRONIC...
(316) 283-8873
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
