GE GSL25JFR Brushed Steel Side by Side Refrigerator
Problem for GE GSL25JFR Brushed Steel Side by Side Refrigerator
Condenser fan is not running. coils are hot and
By sgingerich1 on Nov 07, 2009
condenser fan is not running. coils are hot and the compressor sounds like its working. the evaporator fan is working. The refrigerator is not as cold as it should be
Solution #1
posted on Nov 07, 2009
Not Rated)
co7196
Rank: Wiz
Rating: 84%, 1165 votes
Spin the fan by hand and see if that helps. The condensor fan is causing head pressure to rise and the compressor is fighting it. This in turn will affect the cooling effiviency.Vacuum the cobwebs and dirt that has accumulated and vacumm the fan motor yhrough the vent holes on its end opposit the blades. Spin the fan blades with a pencil to protect your fingers. If the fan still won't turn, it may need to be replaced Good Luck_Ned_
Was this helpful?
Yes
No
Popular Solutions for GE GSL25JFR Brushed Steel Side
Questions and Unsolved Problems for GE GSL25JFR Brushed Steel Side
Do you recommend GE GSL25JFR Brushed Steel Side by Side Refrigerator?
Answer
Answer
fitting bottom left door hinge fridge freezer model whirlpool 63ed22dqxbwoo how do i fit the plastic... (More)
Answer
I have the same problem with GSL25JFTE side by side. I bought it less than 2 years ago. So... (More)
Answer
Hello, The evaporator fan motor changes speeds and makes a low whistle noise at times. It seems that... (More)
Answer
I can get water just fine and it makes ice I just cannot get the ice to come out the door. What Can... (More)
Answer
My freezer has a whisling or howing noise coming from inside the freezer compartment on my side by... (More)
Describe your Refrigerators problem:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top Refrigerator Experts
Top Refrigerator Repairmen
(423) 303-3782
Refrigerator parts delivered overnight nationwide....
 Appliance Parts Pros.com
(619) 564-4488
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
