Question about Hitachi 50UX57B 50" Rear Projection Television
Hitachi 50ux22b has dark screen and general CQ adjustment issues
I have been given A hitachi 50ux22b Rear Projection TV.
The screen is dark and other Quality issues make me feel it is in need of Adjustments.
Does anyone have any logic board schematics or technical data identifing the adjustment areas on the main board?
Thanks in advance
  • 2 more comments
  • progrsys Jan 08, 2008
    No the convergence is not off.
    The picture is dark.
    I have adjusted
    Contrast to 5 clicks past half
    Brightness to 7 clicks past half
    All other settings at half
    All colors present.
    Picture is better.
    maybe thats all it needed...Thanks
  • progrsys Mar 02, 2008
    TV now clicks twice on power button press but no power light or power.
    Problem was correctable by moving chasis slightly but no more.I suspect a cold solder joint..somewhere.
    Thanks for your previous suggestions. Screen Quality was good before power problem.
  • shelties52 Feb 15, 2009
    picture very dark cannnot lighten up through contrast or brightness adjustments
  • 4,402 Answers
Is the convergence off?
bad convergence amp ic's
Posted on Jan 07, 2008
  • Cary Farah
    Cary Farah Jan 08, 2008
    how dark is it? are you getting all three colors red, green blue?
    how far is your brightness turned up? thinking your blue tube might be shoot.
  • Cary Farah
    Cary Farah Mar 03, 2008
    I would look for cold solder joint around the convergence ic and any heat sinked transistors.
Has a black screen. The screen slowly went from dark to darker, then went to dark. I have a Hitachi CLU-572TSI projection tv
Not likely a do it yourself repair---loss of the filament voltage (6.3 volts) in the power supply of the set (some had issues where a resistor changes value).
May 05, 2012 | Hitachi 51G500 51" Rear Projection...
Broken screens on 53'' Hitachi rear-projection TV
I think it would likely work if you trimmed it evenly around the sides in order to maintain the central position. Focus may have to be adjusted but thats all.
Oct 25, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Pictures very dark, Brightness all the way up. Contrast does not adjust
I have the same problem. I was able to temorarily fix the issue by taking the back cover off and blowing all of the dust out. But this only worked for two days. Now the problem is back. Did you fix the issue with your tv? Thanks.
May 28, 2009 | Hitachi 46F500 46" Rear Projection...
Hitachi rear projection tv 50UX22b
Symptom: DEAD
Cause: CHECK I402-IS05-I601
The full repair manual can be found HERE!
May 12, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Hitachi 50UX22B
was it blurry before you cleaned?
you should use lens cleaner and a soft cloth on the lens.
TV: Viewing Screen RPTV - damage and maintenance
Jan 16, 2008 | Hitachi 50UX57B 50" Rear Projection...
46" Rear Projection Hitachi - Green / Yellowish Screen
daveT29 - I had my brightness cranked, too. The picture went dark and off-color after moving the TV from one corner of the living room to another.
After waiting for the TV repairman for about 4 weeks, I "fixed" it myself. Take the front panel off (4 screws, then a black panel) and blow out all the dust. I was afraid to use a swiffer duster because of the static electricity, so i just used with my mouth blowing powers.
That's it. Seriously.
Jan 09, 2008 | Hitachi 46F500 46" Rear Projection...
Hitachi 57F500, Dark areas
Hitachi dark problems at
Dec 27, 2007 | Hitachi 57F500 57" Rear Projection...
53FDX01B Picture went black
is the screen lit up?
If so the video module is bad.
replace the surface mount caps app. 8 to 10
or replace module
Aug 20, 2007 | Hitachi 53FDX01B 53" Rear Projection...
Hitachi 50UX57B 50" Rear Projection Television Logo
184 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
