Home | ASUS | A8N-SLI Premium Motherboard | Can you use the new fle...
ASUS A8N-SLI Premium Motherboard
Problem for ASUS A8N-SLI Premium Motherboard
Can you use the new flexible sli bridges with
By godofdeath50 on Nov 07, 2009
Can you use the new flexible sli bridges with during sli mode?
Do you need the retention bracket thing?
If so what size can you use
Comments:
Nov 08, 2009
- im asking do you need the retention bracket with the flexible sli
because in the site you gave me they dont even bother when they built their computer
and graphics cards dont come with sli bridges its the mobo that does
Solution #1
posted on Nov 07, 2009
Not Helpful)
joecoolvette
Rank: Guru
Rating: 92%, 568 votes
SLI
Scalable Link Interface from Nvidia. (Crossfire is AMD ATI)
You are linking the two interface connections, of two LIKE graphics cards.
The signal and Power connections. A lot of Amp's for power is needed, and a GOOD connection should be used.
Yes, I would definitely advise using the Retention Bracket.
If you have a loose connection, or a connection becomes loose over time, resistance in the connection will be created. Resistance = Heat.
The SLI Bridge connector's (Link) contacts will burn, as well as the contact pins on the graphics cards.
For a while you won't even notice, then as time ensues you start having major problems. By this time the contacts are so burnt, that you may as well fly the graphics cards at the neighbors barking dog.
(The contact pins on the bottom of the graphics card, as well as the PCI Express x16 slot contacts, will burn also. Means NEW motherboard)
Just for added info about SLI, here is SLI Zone from Nvidia,
http://www.slizone.com/page/home.html
(Suggest you start with - Learn - in the top header. Then go to the Community Forums)
Comments:
Nov 07, 2009
- Edit:
Sorry I forgot to add,
Each Nvidia graphics card that is SLI capable, has it's own SLI Bridge available for it.
What two Nvidia GeForce graphics cards are you planning to SLI together?
Nov 07, 2009
- Start with Learn>then click on FAQ in the drop down menu. (Frequently Asked Questions)
Nov 08, 2009
- Excuse me?
Where did you see it stated that they don't use Retention Brackets? Somewhere in the forum?
I gave the link so you would have more info about what Nvidia cards can be SLI'd. Never thought I should run all throughout the forum, and see if sum noob doesn't use a retention bracket! Maybe it was in reference to the old style of the stiff SLI bridges. Still not very intelligent.
Let's look at LOGIC.
1.Most of the big Nvidia cards are 10.5 inches long. 10 and a half inches.
2.They sit in a PCI Express x16 expansion slot, and are locked in, AT THE BOTTOM, and AT THE BACK.
3.The graphics card's metal bracket is attached to the metal frame of the computer case, by a single screw, AT THE FRONT, On TOP.
4.Most of the newer Nvidia cards are WIDE. Therefore, mobo manufacturers have gone to spacing the PCI Express x16 slots away from each other, to compensate for this.
Now you have a longer SLI Bridge.
Couple that with the new style of being FLEXIBLE.
Very thin, very flexible, compared to the OLD style of using the usual stiff PCB construction. (Printed Circuit Board of the FR-4 construction)
YES, the Front of the graphics card will be secured by the metal frame of the computer case.
NO, the back of the card will NOT.
These graphics card's are hanging SIDEWAYS inside the computer. That's around ONE POUND of graphics card (EACH) hanging sideways.
5.Gravity is always 'tugging' down on those graphics cards.
6.Simple vibration of walking across the floor repeatedly, where the computer is located, will make the graphics cards slowly ease over, at the back of the card.
Spreading the two graphics cards at the back over time, and pulling on the SLI Bridge.
Guess what will eventually happen if there isn't anything to hold down on the SLI Bridge?
Retention Brackets are offered by several sources. For this I concede. Mobo Manufacturers, Graphics Card manufacturers, H3ll you can even buy 'em on Ebay!
In reality, LOGIC dictates not even using two Nvidia graphics cards in an SLI configuration.
Not falling into the manufacturers marketing 'trap', of trying to sell what may be an unneeded computer hardware part.
Many buy computer parts based on someone else's uninformed decision.
"Bill states that he has FOUR graphics cards in SLI, and it's GREAT!"
Not true!
Did you know ONE Nvidia GeForce 260GTX, will OUTPERFORM, TWO GeForce 9800GTX's in SLI configuration?
A LOT cheaper too!
Two heads for running dual monitors. Can run a 60" LCD HDTV for a monitor if you wish!
Has 216 CORES!
Was this helpful?
Yes
No
Popular Solutions for ASUS A8N-SLI Premium
Questions and Unsolved Problems for ASUS A8N-SLI Premium
Do you recommend ASUS A8N-SLI Premium Motherboard?
Answer
Answer
asrock wolfdale 1333-d667 display color bars or display disappears after boot or will work for a... (More)
Answer
had root canal saturday tooth chips sunday
Answer
buenas noches, temgo una board msi_k9mm_v_ le acabo de cambiar el hd tenia uno de 250 gg y se lo... (More)
Answer
I just bought a abit kn8 sli motherboard from an auction. I only have one video card so I need the... (More)
Answer
medion ms-7091. problem is bsod when plugging in any usb device. front two usb slots are dead, card... (More)
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For ASUS A8N-SLI Premium...:
Top Motherboard Experts
Rank: Guru Guru
Solutions: 14753
Experience: 40 years of automotive repair work, home appliance repair experience and general electrical repair.
Ask Me
Find more Motherboard Experts
Top Computer & Laptop Repair
(877) 729-0812
We connect to your computer over the Internet to...
Remote Repair
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
